I have a similar problem, that I may have resolved, but I have no USB keyboard [apart from wireless one that doesn’t seem to work with RPi/OSMC
So, I have hard-coded mounts in fstab, then removed partition from spoken hard drive yesterday in rush, before thinking I should remove mount point … now OSMC denies to start.
If OSMC won’t boot because you need to remove UUID from fstab, then your only option is probably gonna be to insert the SDCard into another Linux machine so that you can access the ext4 partition on the card and edit the fstab file.
it’s recommended to make sure you always add the nofail option as one of the mount options. This tells the system that this is not considered to be an “essential” drive, thus it will still boot up (but with an error) if the drive can’t be found.
Yes, additional partitions in fstab that are marked auto but not marked as nofail will cause the system to boot to emergency mode if they can’t be mounted - this includes an external USB media drive that is manually mounted in fstab.
However since the September update when the system boots to emergency mode you will go directly to a root shell so provided you have a keyboard plugged in you could edit /etc/fstab from there to solve the problem.
