At the boot of OSMC, He asks me to connect my external hard drive. Otherwise it will not launch.
My fstab file is correct ?:
UUID=5EFEFAE2FEFAB0FF /media/DDE ntfs-3g defaults 0 2
A solution ?
Thx !
A solution ?
Thx !
Nobody ?
Did you install to USB? Paste /boot/cmdline.txt please.
NO, here paste cmdline.txt:
root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
Removing that drive from fstab fixes it?
What do you mean? OSMC has no function to ask for a drive in order to complete boot. Send a screenshot if you must.
Nothing ?
Why are you trying to manually mount the drive in /media using /etc/fstab ? Just let the automounter (udisks) mount it for you automatically. (Remove your fstab line and reboot)
We have a script which runs on boot which deletes empty mount points in /media before udisks loads, so if you have created a mount point directory called /media/DDE it will be deleted on next boot thus it won’t work.
Please read /media/README.
If I remove the line in fstab, my disc mounts more.
Indeed DDE folder was deleted.
How do I do now ?
Are you saying the disk is mounting automatically, or is not ?
Yes, The disk does not mount automatically.
Nothing.
Really? Did you read /media/README ? If you had then you would know you need to change your fstab mount so it mounts in /mnt instead of /media.
You mean I have to return it in fstab ?
UUID=5EFEFAE2FEFAB0FF /mnt/DDE ntfs-3g defaults 0 2
What I’m doing, but he always asks my startup disk when it is not connected.
I do not know what else to do, or so, I did not understand
I have still not solved my problem. I changed fstab to mount in / mnt.
Can you please remove the fstab lines you have added, run updates to make sure that you are fully updated, reboot, and see if your external drive mounts properly ? If they do not please post a full debug log.
I have fixed a number of automount issues yesterday and pushed out updates to everyone.
That’s what I did and now impossible to start OSMC.
He asks my hard drive. I am blocked. How do I do now ? I can not login via SSH.
I need to modify the fstab file. How make on windows ?
I not delete the line apparently
Plug in a USB keyboard and press Ctrl-D.
Hold down shift on a USB keyboard when you boot and you will get to the recovery console where you can edit /etc/fstab.
