Trying to get this puppy to play ball on latest build. I’m a noob to linux so any help would be appreciated.
I followed this thread
https://discourse.osmc.tv/t/hauppauge-dualhd-not-found-on-vero4k/82839
And now have a green light working on the tuner. My lsmod output (after the modprobe messages) now looks slightly different than the example in the thread above.
[ 1913.486149] usbcore: registered new interface driver em28xx
[ 2069.087422] usb 1-1.2: new high-speed USB device number 6 using xhci-hcd
[ 2069.187425] usb 1-1.2: New USB device found, idVendor=2040, idProduct=8265
[ 2069.187436] usb 1-1.2: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2069.187442] usb 1-1.2: Product: dualHD
[ 2069.187447] usb 1-1.2: Manufacturer: HCW
[ 2069.187451] usb 1-1.2: SerialNumber: 0013974501
[ 2069.187910] em28xx 1-1.2:1.0: New device HCW dualHD @ 480 Mbps (2040:8265, interface 0, class 0)
[ 2069.187921] em28xx 1-1.2:1.0: DVB interface 0 found: bulk
[ 2069.187979] em28xx 1-1.2:1.0: chip ID is em28174
[ 2069.326881] em28xx 1-1.2:1.0: failed to read eeprom (err=-110)
[ 2069.326895] em28xx 1-1.2:1.0: em28xx_i2c_register: em28xx_i2_eeprom failed! retval [-110]
[ 2069.326901] em28xx 1-1.2:1.0: em28xx_init_dev: em28xx_i2c_register bus 0 - error [-110]!
[ 2069.326925] em28xx: probe of 1-1.2:1.0 failed with error -110
osmc@osmc:~$ lsmod
Module Size Used by
em28xx 74017 0
tveeprom 13172 1 em28xx
v4l2_common 4585 1 em28xx
fuse 90351 3
bnep 12492 2
btsdio 3618 0
bluetooth 286328 7 bnep,btsdio
6lowpan_iphc 6159 1 bluetooth
iptable_nat 3340 0
nf_conntrack_ipv4 9173 1
nf_defrag_ipv4 1609 1 nf_conntrack_ipv4
nf_nat_ipv4 4545 1 iptable_nat
nf_nat 15099 2 nf_nat_ipv4,iptable_nat
nf_conntrack 63916 4 nf_nat,nf_nat_ipv4,iptable_nat,nf_conntrack_ipv4
iptable_filter 1686 0
dhd 790896 0
cfg80211 406609 1 dhd
dwc_otg 260876 0
wifi_dummy 886 0
mali 227975 5
ir_lirc_codec 5052 3
lirc_dev 9136 1 ir_lirc_codec
meson_ir 4333 0
rc_core 26059 4 lirc_dev,meson_ir,ir_lirc_codec
amlvideodri 12770 0
videobuf_res 5722 1 amlvideodri
videobuf_core 18318 2 amlvideodri,videobuf_res
videodev 162267 3 amlvideodri,em28xx,v4l2_common
media 24739 2 em28xx,videodev
ip_tables 18759 2 iptable_filter,iptable_nat
x_tables 21080 2 ip_tables,iptable_filter
I guess this means I need firmware/driver files?
Hauppauge have a page for Raspberry OS with firmware instructions but OSMC isn’t Raspberry OS… Will this help or not, or will it just break something?
https://hauppauge.com/pages/support/support_linux.html#pi
Willing to give it a shot if I can easily remove it without a fresh install.
