I have an external 3tb HDD powered by a psu and connected by a hub to the 4k. Recently, it has started disappearing from the system. The only way to get it to reappear is to pull the power on it. I have checked it with fsck and it is clean and there is no click of death. Any idea what the issue may be and how it could be fixed?
reproduce the issue (wait till the hdd disappears)
So, correct your advancedsettings.xml, take another log set (activate logging, 2 x reboot, wait for the hdd to disappear, upload logset and provide the link, here).
btw: Which of the hdds is the one you have issues with?
Jan 03 12:09:47 HTPC kernel: usb 1-2.1: Product: Expansion Desk
Jan 03 12:09:47 HTPC kernel: usb 1-2.1: Manufacturer: Seagate
Jan 03 12:09:47 HTPC kernel: usb 1-2.1: SerialNumber: NA4KQLNL
Jan 03 12:09:47 HTPC kernel: usb 1-2.2: Product: Expansion Desk
Jan 03 12:09:47 HTPC kernel: usb 1-2.2: Manufacturer: Seagate
Jan 03 12:09:47 HTPC kernel: usb 1-2.2: SerialNumber: NA4K6BQY
Jan 03 12:09:47 HTPC kernel: usb 1-2.3: Product: Iomega
Jan 03 12:09:47 HTPC kernel: usb 1-2.3: Manufacturer: Iomega
Jan 03 12:09:47 HTPC kernel: usb 1-2.3: SerialNumber: FF2000DF000000000000006FD1FFFC
Jan 03 12:09:47 HTPC kernel: usb 1-2.4.1: Product: Elements 25A3
Jan 03 12:09:47 HTPC kernel: usb 1-2.4.1: Manufacturer: Western Digital
Jan 03 12:09:47 HTPC kernel: usb 1-2.4.1: SerialNumber: 57583331443439483550544A
Great. That’s got it. Thanks for your help. Will post back when it occurs but its
