HDMI/ARC problem
Hello,
LG C8 TV
LG SL8YG Soundbar
I have a problem with Vero+Soundbar LG SL8YG.
Audio everything works wonderfully.
HDMI1= Vero4+
HDMI2= LG SL8YG ARC connection
HDMI3=PS4
TV Antenna
LG Webos Youtube
When I connect Vero4k HDMI Not I get ARC automatically, on soundbar,Everything works.
When I connect Vero4k+ HDMI I get no sound ARC is only OPTICAL.
If I turn on Vero4k then I get ARC again everywhere.
I do not understand this.
It has to do with Simplink I think, but why does this happen?
with kind regards
Hello
Problem solved.
I have connected Toslink cable to it
Arc HDMi and Optical cable now it all works
I’m glad things now work as expected – but didn’t quite understand your original problem
Hello Sam
Thanks, I’m still having problems unfortunately.
Sorry about my english
The problem has vero4k+
I have a soundbar LG SL8YG
Connected with ARC.
HDMI 1 Vero4k
HDMI 2 LG Soundbar ARC
HDMI 3 PS4
ARC only works when I have VERO4k+ power.
When I turn off Vero4k, ARC sound no longer works.
I turn off Vero4k+.
Then goes sound to internal speakers and optical.
Where can I set that ARC works for me.
If I do not connect Vero4k+ HDMI:
Everything goes without problems with ARC connection.
It does not matter where I connect Vero4k+.
With kind regards
  • Why you don’t connect the Vero to the HDMI-in port of the LG soundbar?
  • The Vero is not designed to be “turned off” (it has no power button) and should be “on” all the time since the power consumption is very low. Or do you mean the “suspend mode” of the device?
  • Just as a test try to deactivate CEC on the Vero (you need set the “settings level” to “standard” or higher) and tell us what happens then:
Hi JimKnopf,
thanks
CEC is turned off.I have already tried this.
Unfortunately no success
When red cross lights everything goes, only when I completely remove power soundbar goes from ARC to Optical.
I connect Vero4k+ HDMI in to Soundbar.
And will report back. Thanks
With kind regards
Hallo JimKnopf,
danke
CEC ist ausgeschalten.Ich habe das schon ausprobiert.
Leider kein erfolg
Wenn Rotes Kreuz leutet geht alles,
Nur wenn ich komplett Strom wegnehme geht Soundbar von ARC auf Optical.
Danke
Ich Schliesse Vero4k+ HDMI in an Soundbar Anschliessen.
Und werde berichten. Danke
Mit freundlichen Grüßem
Hello,
I have no success.
Vero4k+ I have connected to soundbar HDMI get no picture.
Turn on TV.soundbar goes to OPTICAL.
Turn on Vero4k+ Soundbar goes to ARC.
Turn Vero4k off (standby) red cross.
ARC goes on.
Turn off TV.
Turn TV on
Soundbar goes to OPTICAL. Vero4k is in standby Red cross.
Turn power off and on at Vero4k+.Vero4k+ starts up.
After 2 seconds I get ARC.
I do not understand what the problem with Vero4k.
Other HDMI cable also does not work.other HDMI connection same problem.
This only happens with Vero4k.Vero4k+ completely controls my ARC
With kind regards
Hallo,
ich habe kein Erfolg.
Vero4k+ habe ich an Soundbar angeschlossen HDMI bekomme kein Bild.
Schalte Fernsehen an.Soundbar geht auf OPTICAL.
Schalte Vero4k+ an Soundbar geht auf ARC.
Schalte Vero4k aus (Standby) Rote Kreuz.
ARC geht weiter.
Schalte Fernsehen aus.
Soundbar geht auf OPTICAL. Vero4k steht in Standby Rotes Kreuz.
Schalte Strom bei Vero4k+ aus und an.Vero4k+ fährt hoch.
Nach 2 sekunden bekomme ich ARC.
Ich verstehe nicht was der für ein Problem mit Vero4k hat.
Andere HDMI kabel geht auch nicht.Andere HDMI Anschluss gleiche Problem.
Das Passiert nur bei Vero4k.Vero4k+ Steuert komplett mein ARC
Danke
Mit freundlichen Grüßen
Hello,
I am glad that I am not alone with my problem.
Most of the problems come from LG
I also have a LG OLED C8
This is my problem post here.I have exactly the same problem, with ARC :slight_smile:
I read this topic thoroughly.
Hallo,
ich bin froh das ich mit mein Problem nicht alleine stehe.
Die meisten probleme kommen von LG
Ich habe auch ein LG OLED C8
Das ist mein Problem beitrag hier.Ich habe genau das gleiche Probleme, mit ARC :slight_smile:
Ich lese diese Thema Gründlich.
