I just plugged in my Vero 2 and restored backed up settings from Vero 1, but CEC is not working at all. I seem to remember the settings being under “peripherals” in input, but that is greyed out. Am I missing something? How do I change CEC settings on Vero 2?
For example, when I change the volume on Vero 1, it adjusts the volume on my receiver. On Vero 2 it adjusts the internal volume (i.e., not useful).
I have Vero plugged into an Onkyo TX-NR808 receiver that outputs to an Epson Powerlight 3020.
I suppose I could plug the projector directly into the Vero (sort of a pain in the neck though), but the only feature that I a interested in is controlling the receiver volume from the Vero remote, so communication with the receiver is what I need to fix.
It’s a real bummer, too, because I much prefer the RF remote on the Vero 2.
Ok, tried plugging into the projector directly, still nothing. This is what dmesg outputs when I switched cables and pressed buttons on the projector remote:
The projector remote does still control the volume on the receiver and the Steam Link still switches inputs automatically, so it seems the Vero is the only device not working with CEC.
I called up the “HDMI Link” menu on the projector and it sees Vero as “MBox.” I used the projector to switch to another input (Chromecast) and then back to “MBox.” It did, indeed switch to Vero and it activated the “Power” menu (i.e., it was showing the power sub-menu when it switched inputs back to Vero).
Once it switched back, however, MBox (Vero) no longer showed up in the menu and this popped up in dmesg:
[Fri Feb 19 17:04:11 2016] hdmitx: cec: CEC task process
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC node init
[Fri Feb 19 17:04:12 2016] hdmitx: cec: cec_func_config: 0xf; P_AO_DEBUG_REG0:0xf
[Fri Feb 19 17:04:12 2016] hdmitx: cec: Set PWM_E out put RTC 32K!
[Fri Feb 19 17:04:12 2016] hdmitx: cec: enable:int mask:0x6
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC: start poll dev
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC_LOGICAL_ADDR0:0x1f
[Fri Feb 19 17:04:12 2016] hdmitx: cec: now tx_stat:0
[Fri Feb 19 17:04:12 2016] hdmitx: cec: start poll
[Fri Feb 19 17:04:12 2016] hdmitx: cec: end poll, tx_stat:2
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC: poll online logic device: 0x4 BOOL: 1
[Fri Feb 19 17:04:12 2016] hdmitx: cec: player_dev[0]:0x4
[Fri Feb 19 17:04:12 2016] hdmitx: cec: end poll, tx_stat:0
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC: poll online logic device: 0x8 BOOL: 1
[Fri Feb 19 17:04:12 2016] hdmitx: cec: player_dev[1]:0x8
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC_LOGICAL_ADDR0:0x0
[Fri Feb 19 17:04:12 2016] hdmitx: cec: CEC: poll online logic device: 0xb BOOL: 1
[Fri Feb 19 17:04:12 2016] hdmitx: cec: player_dev[2]:0xb
[Fri Feb 19 17:04:12 2016] hdmitx: cec: Can't get a valid logical address
[Fri Feb 19 17:04:47 2016] hdmitx: cec: aocec irq 4
Sending the reset command did not make MBox (vero) reappear in the HDMI Link menu. Only rebooting Vero made it reappear.
To summarize, there is some form of communication because the projector “sees” Vero as something called “MBox,” but switching inputs via the projector generates a “Can’t get a valid logical address” error and removes it from the projector HDMI Link menu.
Now, all of a sudden, the projector remote controls Vero!
[Fri Feb 19 17:14:35 2016] hdmitx: cec: CEC task process
[Fri Feb 19 17:14:35 2016] hdmitx: cec: aocec irq 4
[Fri Feb 19 17:14:35 2016] hdmitx: cec: CEC[11]: rx msg len: 2 dat: 0b 45
[Fri Feb 19 17:14:36 2016] hdmitx: cec: aocec irq 4
[Fri Feb 19 17:14:36 2016] hdmitx: cec: CEC[11]: rx msg len: 3 dat: 0b 44 01
[Fri Feb 19 17:14:36 2016] hdmitx: cec: : Key pressed
[Fri Feb 19 17:14:36 2016] hdmitx: cec: :operands_irq[0]:0x1
[Fri Feb 19 17:14:36 2016] hdmitx: cec: :key map:103
[Fri Feb 19 17:14:36 2016] hdmitx: cec: CEC task process
[Fri Feb 19 17:14:36 2016] hdmitx: cec: CEC[11]: rx msg len: 2 dat: 0b 45
But Vero still does not control the receiver volume (which, sadly, is the only thing I need to work). I should mention that with Vero 1, CEC was really flaky and needed to be rebooted while the receiver was on in order to function correctly. (Though once it started working it would stay that way until Vero power cycled or installed an update while the receiver was off, so like, weeks.)
You will get more control when we complete the libCEC port
If I understand you correctly the volume key is controlling the TV rather than the device, but some other buttons work. I’m not sure yet what must be done to capture the volume button, but I will try and investigate
No, I don’t have a TV. The volume key controls only Vero’s internal volume.
Here is a summary:
• I want the volume controls on osmc to control my AV receiver via cec, but it instead only adjusts the analog volume on Vero 2 (i.e., it says “Volume xxx%”)
• My projector sometimes manages to connect to Vero 2 and its remote allows me to navigate menus on osmc, but it stops working a few minutes after restarting Vero.
• Vero does receive power on/off events via cec, which toggle the “power” menu when I switch on the projector or AV receiver. But apparently nothing else (at least, consistently.)
• All of my other devices (AV receiver, projector, Steamlink and Chromecast) communicate perfectly over cec.
There is another one working on a cec driver for amlogic that supports libcec? My driver for the Wetek Play/Core is not perfekt but works better and better. I would like to exchange experiences with this other developer. Who is it?
I took a look at your work on the new kernel driver and libCEC userland work. I didn’t get it to work on Vero 2, and assumed that it was specific to WeTek Play. I haven’t had time to look at why yet.
The only TV I have which implements CEC is an LG 32LH3000 which I have limited access to, so this is slowing me down. There is definitely a race condition: sometimes I can get CEC to work using the current in-kernel driver and sometimes it needs a reset (which also seems problematic). Documentation for this driver seems non-existent.
Userland implementation will be better for fine grained control (repeat filter), disabling the driver without /proc/cmdline changes anyway.
I merged Gerald’s (@gda) latest work and it appears to be working well. It’s much improved over the AMLogic CEC driver and will provide configuration for things like repeat presses and make it easier to toggle CEC as these settings will be available via the Peripherals menu in Kodi as they are on other platforms
