Sadly it still plays up on my latest setup ![]()
I only have one possible solution (in my mind) left.
Give me a couple of days.
Any joy Sam the man?
Itâs not forgotten. I canât reliably test it but I will make testing available to you shortly.
Done what I canâŚ
To test this update:
- Login via the command line
- Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
ok
Iâve installed that update.
Will see how it goes and report back.
For me, that update bricked CEC completely for the vero4k. I cannot control the volume for my soundbar from my vero remote and the TV doesnât turn on/off anymore
Did you power down everything from the mains after updating for a couple of minutes?
Yes, also changed some CEC settings in kodi but nothing so far
Some logs would help, otherwise I will revert the changes back (little feedback here but want to release an update soon) and draw a line under it.
I have sent you some logs via message
Update from me is that CEC has stopped working.
Please try and keep settings consistent. Introducing more variables is not good.
I can see the cause for CEC not working.
Can you try updating as suggested above and giving some feedback?
CEC is working again, awesome!
But I need a few days to confirm whether your changes stabilized it over time.
Applied this 5 days ago, did have HDMI CEC on the Vero completely stop working about a day in (other systems continue to work), but a power cycle to the Vero since appears to have restored HDMI CEC controls.
No issues with HDMI CEC to report so farâŚ
After applying the above update I am hoping everyone does a cold start (so everything is powered down from the mains)
I hadnât initially done a full power cycle, but I have done two since then (electrical work in the house so EVERYTHING was off twice in 2-days). Those FULL power cycles were on Friday & Saturday.
It is still working this morning (Monday). Will report back in a few days, or earlier if anything changes.
Still working ok this morning (Tuesday), but I need to turn the power circuit off in the house again later today, so will be another power cycle.
Is it behaving longer than usual for you?
It wasâŚ!!
Following todayâs house power cycle, CEC hasnât worked and I get an unhappy face on the blue screen when the Vero 4k restarts.
Log:
https://paste.osmc.tv/vewuwowabi
Edit:
a âRebootâ didnât bring CEC back, but a âPower off systemâ then remove power and a wait before repowering has returned CEC.
Iâll see how it goes.
