HDMI - Pink screen sometimes
So…I have added the line via ssh…saved it, does it look right?, may have done it twice because when I Cyberduck into it I have 3 versions…I rebooted and got the same blank screen…how do I delete the first two versions please?fullsizeoutput_352 fullsizeoutput_353
Thanks again…feel the light is at the end of the tunnel…
M
They generally will be ignored. But you can remove them with sudo rm rc.local.save and sudo rm rc.local.save.1
Looks tight based on the instructions. But maybe @grahamh made a mistake and it should be
echo 8bitnow > /sys/class/amhdmitx/amhdmitx0/attr
Ok…so this latest script isn’t working either…also I can’t delete the other files …eek…see picture below:fullsizeoutput_354
There should be no need for the now in rc.local but no harm either. And no harm to the rc.local.save.* files.
Please re-boot and post logs from ssh with grab-logs -A.
Thanks.
Just enabled de bugging, rebooted and blank screen now…so got logs and here they are:
https://paste.osmc.tv/gapufojucu
Cheers,
M
Run: cat /etc/rc.local | paste-log and post the URL
https://paste.osmc.tv/izuhaluvok
This is the problem:
Nov 26 13:41:16 osmc systemd[388]: rc-local.service: Failed to execute command: Exec format error
Nov 26 13:41:16 osmc systemd[388]: rc-local.service: Failed at step EXEC spawning /etc/rc.local: Exec format error
Nov 26 13:41:16 osmc systemd[1]: rc-local.service: Control process exited, code=exited, status=203/EXEC
Nov 26 13:41:16 osmc systemd[1]: rc-local.service: Failed with result 'exit-code'.
Nov 26 13:41:16 osmc systemd[1]: Failed to start /etc/rc.local Compatibility.
You need to remove that empty line you added before
#!/bin/sh -e
well…I’m in there but don’t know how to remove the empty line…any pointers please?!
M
I’ve got into the bit to edit file just can’t delete the first line…here is my photo of where I am.I can see my cursor, just can’t delete the line…:slight_smile:fullsizeoutput_355
to answer my post I managed to delete the file with a back space, saved it, rebooted and screen blank. Had to ssh into to see sudo nano /etc/rc.local and it had the first line back again…
M
On Windows,the delete key removes those blank lines.
Or backspace when you are on the line that starts #!
Right, I have 8 rc.local files, the last one save 6 has the correct structure…i.e no line at the beginning…if I could delete all the stuff before it I think this would work ad the others all have the space:fullsizeoutput_356
sudo rm /etc/rc.local
sudo mv /etc/rc.local.save.6 /etc/rc.local
Then please post output of
ls -l /etc/rc.local
I’ve done as requested and it says ‘no such file or directory’
fullsizeoutput_357
I didn’t ask you to rm rc.local after the mv !!
Now you’ve lost it.
What have you got left now?
ls -l /etc/rc.local*
sorry…whole new world this…this is what I have left…fullsizeoutput_358
cat /etc/rc.local
done that…here’s the piccy:
fullsizeoutput_359
