hi guys, i just got my vero 4K today, first think i did was update to the last version, everything is fine, the only problem that i have is the vero 4k lose the hdmi input signal constantly, if i play a movie and stop it lose the hdmi signal and i have to go to my basement and unplug the power and plug it back, i have HTPC, AppleTV, Nvidia Shield and have 0 problem, Yamaha 5100 and Sony 940 TV, i try 3 different HDMI Cables including the one that comes with vero 4k and different input and still have the same problem
this happen using Kodi skin or OSMC Skin, please tell me what info you need from me, this is my first vero
i also trying to reset kodi, so i go to manual and select reset kodi after reboot, so i check that press ok and after reboot kodi dint reset everything stay intact, what would be the best way to complete reset vero 4k to factory default
here are logs let me know if you need anything else
Please take a photo of the environment the box is situated in, and confirm you’re using the official power supply which is powered directly to the wall (no extension chords).
here there is plenty of air space, the cpu on idle is running 64c, can you please tell me what network problem you see because like i say i have HTPC Running Librelec, shield with kodi and i dont have any network problem with a 96 tb unraid server, also how can i get you debug log so next time if crash you can have more info
i got to say, i move the power supply that came with vero 4k to a different outlet and everything is better now, i just finish watching my first 4K HDR and sound and video was stunning no more crash, i enable kodi debug log, how do i get it so i can post it here? i still have some HDMI Signal lost whit a few 4K HDR Movies and will like to know what the problem could be
