I have tried it with 4 different cables, one of which is premium certified. Makes no difference.
Strangely now I cannot get any 4K file to play at all. So I have had to use Sam’s hotfix to roll back the October changes and now all the files play straight away.
Sam - is there a way to get back to the ‘vanilla’ Oct update (before Graham’s latest update) or do I have to completely re-install and then load a backup?
I finally managed to take some time to test vero364-image-3.14.29-128-osmc on my LG 65C8.
Note that I am on krypton (not leia) and the Vero 4k is plugged into a soundbar (LG SK10Y) plugged into the TV.
No forcing to /sys/class/amhdmitx/amhdmitx0/attr --> works fine (HDR OK, no banding, …) except sometimes the TV shows the “no signal” screen and I need to relaunch the video.
Forcing 10bit --> basically the same
Forcing 422now --> basically the same
I just made another few tests. Ran the “Planet Earth II” sample (Test-2160p.HEVC.HDR.DTS-HD.MA.mkv, 15mn long, that I got from the kodi “Samples” wiki IIRC).
I get the “No signal” randomly, 1 out of 7-8 launches. Nothing forced to attr.
OK. I enabled logging, rebooted the device and ran the same sample video (“Planet Earth II”) roughly 10 times.
The first few runs were fine. When I stopped the video after run #5 (or #6 maybe), the TV showed "No signal instead of KODI’s main menu for a couple of seconds, then the main menu showed up.
I kept on going for another few runs (I’d say +/- 5) until the TV showed the “No signal” instead of the video. Then I captured the logs (grab-logs -A -C), and uploaded them: https://paste.osmc.tv/okelaxosob
So I have done some more playing around with the latest kernel and have discovered that the length of the cable seems to be causing the problem. All the cables I tested with previously were 3m long, as I need to use this length due to having the TV mounted and trunking in the wall. But I just tried it with the short cable that comes with the Vero and (almost) every 4K file plays first time. I then tried an older 2m cable and the success rate went down but still better than the 3m.
It’s like the Vero isn’t sending a strong enough signal for the length of cable. Which is strange as when I used Sam’s hotfix to roll back the October changes the files played fine with the 3m cable.
FWIW I can play 4k videos at 444,422 or 420 and 8 and 10 bits on my Panasonic through a 6m long cable I bought for £12 in Sainsbury’s. Branded Blaupunkt.
AFAIK, nothing about the HDMI PHY has changed since August but we’ll check again. Thanks for the feedback.
Not yet, but this is proving a puzzle. With latest kernel (129) I do believe everyone else’s issues come down to bandwidth limitations of cables and/or some way in which their AVR is mangling the EDID from the TV.
Please post logs again with the latest kernel. Start with UHD color off, play a 4k60Hz vid, then turn on UHD color and play the vid again. Also post the output of cat /sys/class/amhdmitx/amhdmitx0/config while playing the video.
If you get a blankscreen, does echo now | sudo tee /sys/class/amhdmitx/amhdmitx0/attr (issued while it’s blank) restore it?
As a reality check, can you confirm that 4k60Hz vid plays at 1080p, 10bit, by turning off adjust refresh rate.
All of that tells me vero is doing exactly what it’s supposed to do.
I would be very surprised at that. It might have played with 8 bits.
Now we have to ask if you are able to get a 4k10bit picture on that TV with any other device attached through HDMI. (Playing a file through USB doesn’t count, but if that doesn’t work, you really are in trouble!)
Your TV seems to have an obscure setting called ‘HDR+’. Presumably you have tried that both ways.
echo 42010bitnow | sudo tee /sys/amhhdmitx/amhdmitx0/attr
but only if you have set the resolution to 2160p60Hz first. You will probably find just trying to set that resolution gives you a blank screen, since 420,10bit is the default.
So while 420 10 bit is somewhat () pink, it works. 422,10/12 bit @ 60Hz works perfect. No visible banding in my usual demo. RGB 12 bit @ 24Hz works perfect, too.
This is with the most recent MadVR using mostly default settings. Forced the display modes in NVIDIA control panel.
For some reason though, Vero4k can’t seem to do this. OliC seems to have the exact same problem so I’m confident that the problem is not on my side but some strange interaction between Samsung and Vero4k.
Thanks for that! It’s difficult to read, but I wonder whether the clock deviation of (?) 0.1% in the 420,10bit (pink) case is significant. The others are at least an order of magnitude better.
Is that information printed by the TV or the graphics card?
Olic’s is a LG.
We haven’t managed to test 422 at 2160p60Hz on LGs or Samsungs yet. I’m hoping @obstler42 will do it, but you could try the same instructions I gave him. On Nvidia at least 422 seems to be working better than 420.
I tried the commands, here are the results: echo 8bitnow | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
-> Switched to 8 bit. Works.
echo 2160p60hz | sudo tee /sys/class/display/mode
-> Switched to 8 bit, 420. Still works.
echo 2160p60hz420 | sudo tee /sys/class/display/mode
-> Already was there, so no change. Still works.
echo 42210bitnow | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
-> Switches to 10 bit, 420. Black screen.
I can’t seem to force 422. It doesn’t seem to stick, even if I try… echo 422 | sudo tee /sys/class/amhdmitx/amhdmitx0/attr
… config always stays at:
cur_VIC: 353
VIC: 353 3840x2160p60hz
Colour depth: 10-bit
Colourspace: YUV420
Colour range: limited
EOTF: SDR
YCC colour range: limited
PLL clock: 0xc000029a, Vid clock div 0x000b0000
audio config: on
3D config: off
I bought a Fire TV Stick 4K (hurray Cyber Monday). But I still like my Vero4k and really want it to work.
Oh and one more thing:
cur_VIC: 93
VIC: 93 3840x2160p24hz
Colourspace: YUV444
EOTF: HDR10
audio config: on
3D config: off
A 4k24fps movie… guess what? Black screen. Same movie as the last screen, where it played in 12 bit, full RGB.
