hii Today I work with tvheadend But it does not work for me very well how long he stuck me Is there any software that I can work and easy as tvheadend tanks
HarryL
7 September 2015 09:28
2
take a look at this how to:
Testet with Tvheadend 4.0.5 on OSMC 2015.06-1 stable with RPI2
When you have installed Tvheadend from the Appstore, then go to Tvheadend “admin” interface by using this URL http://osmc.local .:9981 or http://OSMC_IP:9981 and login with osmc/osmc (can be changed later).
First be sure that Tvheadend can see your DVB tuner under “Configuration” → “DVB Inputs” → “TV adapters” should look something like this:
[image]
Same approach should work with HDhomerun network tuner with the new build
that…
if any problems, then take some screenshot and lets look at them…
-H
