Hi, I’ve been trying to get 5.1 audio file to play in 5.1.
I’ve tested Ogg, Mka, and Flac but they all seem to play in stereo.
I have RPI2 and hifiberry digi. Passthrough enabled (although passthrough device says HDMI and greyed out so can’t change it)
Movies play fine in 5.1 though so must be using hifiberry.
I added the file but now all the test files play with no audio and osmc crashes when I stop playback.
I deleted the playercorefactory.xml file but still get no audio and crash when I stop playback.
Yeah restarted, mp3’s play fine but two 5.1 audio files (ogg,mka) which I added to the playercorefactory.xml file are silent and (sometimes) crash osmc.
I forgot I was using a clean install of osmc, movies do not play with sound, hifiberry isn’t setup right for passthrough which is why passthrough device only shows hdmi and I can’t choose hifiberry.
I found this thread which seems as though there’s a bug in the kernel.
Soundcard overlay is set to hifiberry-digi-overlay
Audio output device only has snd_rpi_hifiberry_digi analog
There’s no snd_rpi_hifiberry_digi SPDIF option.
Just tried my old SDCard with 2019.07-1 (kernel: Linux 4.14.78-4 ) and it plays the 5.1 files in 5.1 with no code edit needed so will wait for update.
