Hi everyone, and thanks for the great work! I have a Hifiberry DAC+ on a RP2 which was working well until the Matrix upgrade. I followed the HifiBerry DAC+ Overlay not working OOTB solution, but the sound card is still not detected. Please help me sort this out.
I have hifiberry-dacplus-overlay selected under Hardware Support. Only bcm2835 audio output devices (HDMI and headphones) are listed in the settings.
Furthermore, aplay does not list the DAC:
> aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: b1 [bcm2835 HDMI 1], device 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
Subdevices: 3/4
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headphones]
Subdevices: 4/4
Here’s my config.txt:
[pi4]
dtoverlay=rpivid-v4l2
arm_64bit=1
kernel=kernel.img
[all]
dtoverlay=vc4-fkms-v3d,cma-512
disable_overscan=1
start_x=1
disable_splash=1
disable_fw_kms_setup=1
include config-user.txt
My config-user.txt:
gpu_mem_1024=256
gpu_mem_256=112
gpu_mem_512=144
sdtv_aspect=1
start_x=1
dtoverlay=hifiberry-dacplus
dtparam=audio=on
And my dmesg output:
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Linux version 5.10.32-2-osmc (root@osmc) (gcc (Debian 8.3.0-6) 8.3.0, GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP PREEMPT Mon Aug 2 04:28:32 UTC 2021
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x0ec00000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] DMA zone: 2133 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50892 r8192 d22836 u81920
[ 0.000000] pcpu-alloc: s50892 r8192 d22836 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 416092K/970752K available (11264K kernel code, 1313K rwdata, 2904K rodata, 3072K init, 862K bss, 30372K reserved, 524288K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 29635 entries in 58 pages
[ 0.000000] ftrace: allocated 58 pages with 4 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x3b4/0x584 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000029] Switching to timer-based delay loop, resolution 52ns
[ 0.000370] Console: colour dummy device 80x30
[ 0.000467] printk: console [tty0] enabled
[ 0.000546] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000591] pid_max: default: 32768 minimum: 301
[ 0.000853] LSM: Security Framework initializing
[ 0.001172] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001214] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003603] Disabling memory control group subsystem
[ 0.003793] CPU: Testing write buffer coherency: ok
[ 0.004643] CPU0: update cpu_capacity 1024
[ 0.004673] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.007151] Setting up static identity map for 0x100000 - 0x10003c
[ 0.007511] rcu: Hierarchical SRCU implementation.
[ 0.009085] smp: Bringing up secondary CPUs ...
[ 0.011343] CPU1: update cpu_capacity 1024
[ 0.011360] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.013620] CPU2: update cpu_capacity 1024
[ 0.013635] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.015811] CPU3: update cpu_capacity 1024
[ 0.015825] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.016120] smp: Brought up 1 node, 4 CPUs
[ 0.016158] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.016175] CPU: All CPU(s) started in HYP mode.
[ 0.016190] CPU: Virtualization extensions available.
[ 0.017660] devtmpfs: initialized
[ 0.042173] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.042582] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.042636] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.073536] pinctrl core: initialized pinctrl subsystem
[ 0.075631] NET: Registered protocol family 16
[ 0.081116] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.088759] audit: initializing netlink subsys (disabled)
[ 0.090567] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[ 0.090699] thermal_sys: Registered thermal governor 'step_wise'
[ 0.091527] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.091550] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092002] Serial: AMBA PL011 UART driver
[ 0.120343] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.141700] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-03-10T10:15:19, variant start_x
[ 0.151710] raspberrypi-firmware soc:firmware: Firmware hash is 4b9ea44619376439c801684745a12299b45ae2bb
[ 0.209766] Kprobes globally optimized
[ 0.218408] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.221807] SCSI subsystem initialized
[ 0.222673] usbcore: registered new interface driver usbfs
[ 0.222772] usbcore: registered new interface driver hub
[ 0.222886] usbcore: registered new device driver usb
[ 0.225235] clocksource: Switched to clocksource arch_sys_counter
[ 2.015619] VFS: Disk quotas dquot_6.6.0
[ 2.015785] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.016121] FS-Cache: Loaded
[ 2.016630] CacheFiles: Loaded
[ 2.018136] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes, mapped to 0x(ptrval)
[ 2.018171] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 2.019117] Console: switching to colour frame buffer device 240x67
[ 2.057562] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 2.076030] NET: Registered protocol family 2
[ 2.078110] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 2.078177] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 2.078311] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 2.078516] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.078815] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 2.078907] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 2.080033] NET: Registered protocol family 1
[ 2.081559] RPC: Registered named UNIX socket transport module.
[ 2.081581] RPC: Registered udp transport module.
[ 2.081599] RPC: Registered tcp transport module.
[ 2.081615] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.217668] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 2.224398] Initialise system trusted keyrings
[ 2.225031] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 2.238365] zbud: loaded
[ 2.241387] FS-Cache: Netfs 'nfs' registered for caching
[ 2.242781] NFS: Registering the id_resolver key type
[ 2.242855] Key type id_resolver registered
[ 2.242874] Key type id_legacy registered
[ 2.243101] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.243123] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.244892] Key type asymmetric registered
[ 2.244920] Asymmetric key parser 'x509' registered
[ 2.245015] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 2.245605] io scheduler bfq registered
[ 2.258616] bcm2835-rng 3f104000.rng: hwrng registered
[ 2.259334] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 2.260814] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 2.281295] brd: module loaded
[ 2.298951] loop: module loaded
[ 2.301467] Loading iSCSI transport class v2.0-870.
[ 2.304060] libphy: Fixed MDIO Bus: probed
[ 2.304542] usbcore: registered new interface driver lan78xx
[ 2.304649] usbcore: registered new interface driver smsc95xx
[ 2.304692] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 3.033259] Core Release: 2.80a
[ 3.033285] Setting default values for core params
[ 3.033326] Finished setting default values for core params
[ 3.233815] Using Buffer DMA mode
[ 3.233837] Periodic Transfer Interrupt Enhancement - disabled
[ 3.233854] Multiprocessor Interrupt Enhancement - disabled
[ 3.233875] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.233898] Dedicated Tx FIFOs mode
[ 3.235483] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 8ed04000 dma = 0xced04000 len=9024
[ 3.235530] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 3.235550] dwc_otg: Microframe scheduler enabled
[ 3.235810] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.235833] WARN::hcd_init_fiq:458: FIQ ASM at 808fc184 length 36
[ 3.235857] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
[ 3.235893] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.235959] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.236037] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.236101] Init: Port Power? op_state=1
[ 3.236119] Init: Power Port (0)
[ 3.236718] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.236745] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.236766] usb usb1: Product: DWC OTG Controller
[ 3.236786] usb usb1: Manufacturer: Linux 5.10.32-2-osmc dwc_otg_hcd
[ 3.236808] usb usb1: SerialNumber: 3f980000.usb
[ 3.238195] hub 1-0:1.0: USB hub found
[ 3.238311] hub 1-0:1.0: 1 port detected
[ 3.240002] dwc_otg: FIQ enabled
[ 3.240025] dwc_otg: NAK holdoff enabled
[ 3.240043] dwc_otg: FIQ split-transaction FSM enabled
[ 3.240069] Module dwc_common_port init
[ 3.240648] usbcore: registered new interface driver usb-storage
[ 3.241090] mousedev: PS/2 mouse device common for all mice
[ 3.243160] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.248852] sdhci: Secure Digital Host Controller Interface driver
[ 3.248870] sdhci: Copyright(c) Pierre Ossman
[ 3.249663] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.249970] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.250985] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.251340] hid: raw HID events driver (C) Jiri Kosina
[ 3.251567] usbcore: registered new interface driver usbhid
[ 3.251581] usbhid: USB HID core driver
[ 3.257425] Initializing XFRM netlink socket
[ 3.257482] NET: Registered protocol family 17
[ 3.257646] Key type dns_resolver registered
[ 3.257787] Registering SWP/SWPB emulation handler
[ 3.257982] registered taskstats version 1
[ 3.258021] Loading compiled-in X.509 certificates
[ 3.259170] Key type ._fscrypt registered
[ 3.259185] Key type .fscrypt registered
[ 3.259199] Key type fscrypt-provisioning registered
[ 3.273221] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.273362] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.276080] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.278095] sdhost: log_buf @ (ptrval) (ced03000)
[ 3.327030] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.330997] of_cfs_init
[ 3.331225] of_cfs_init: OK
[ 3.352448] Freeing unused kernel memory: 3072K
[ 3.352808] Run /init as init process
[ 3.352822] with arguments:
[ 3.352832] /init
[ 3.352844] with environment:
[ 3.352854] HOME=/
[ 3.352863] TERM=linux
[ 3.352875] osmcdev=rbp2
[ 3.414910] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.419727] mmc0: new high speed SDHC card at address aaaa
[ 3.421063] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 3.423341] mmcblk0: p1 p2
[ 3.456007] Indeed it is in host mode hprt0 = 00021501
[ 3.541844] random: fast init done
[ 3.665389] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.665615] Indeed it is in host mode hprt0 = 00001101
[ 3.719329] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.738137] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 3.738510] fsck: Filesystem UUID: a04e061c-afee-46a8-abe1-281717a99a3a
[ 3.738906] fsck: /dev/mmcblk0p2: clean, 141682/958464 files, 1332554/3826688 blocks
[ 3.905714] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00[ 3.905748] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.906748] hub 1-1:1.0: USB hub found
[ 3.906892] hub 1-1:1.0: 5 ports detected
[ 4.225340] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.355919] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 4.355955] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.359187] smsc95xx v2.0.0
[ 4.563102] libphy: smsc95xx-mdiobus: probed
[ 4.564291] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:56:e2:3f
[ 5.779319] systemd[1]: System time before build time, advancing clock.
[ 5.857165] NET: Registered protocol family 10
[ 5.859160] Segment Routing with IPv6
[ 5.935867] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.936846] systemd[1]: Detected architecture arm.
[ 5.980095] systemd[1]: Set hostname to <tv-living>.
[ 6.632536] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.777713] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.778297] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.778894] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.779579] systemd[1]: Listening on udev Kernel Socket.
[ 6.780648] systemd[1]: Listening on Journal Socket.
[ 6.792670] systemd[1]: Starting Load Kernel Modules...
[ 6.801607] systemd[1]: Starting Restore / save the current clock...
[ 6.810361] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.819443] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.950191] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.391615] systemd-journald[152]: Received request to flush runtime journal from PID 1
[ 10.974170] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.980874] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 10.983290] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 10.983317] [vc_sm_connected_init]: start
[ 10.984204] [vc_sm_connected_init]: installed successfully
[ 11.010241] mc: Linux media interface: v0.10
[ 11.045795] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 11.065949] videodev: Linux video capture interface: v2.00
[ 11.126277] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.126283] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.126288] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.147330] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 11.169404] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.175501] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.181162] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 11.181874] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 11.182737] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 11.183328] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 11.183466] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 11.183500] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 11.183528] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 11.183548] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 11.183588] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 11.184120] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 11.568439] vc4-drm soc:gpu: bound 3f600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 11.571868] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 11.571920] checking generic (3e402000 7f8000) vs hw (0 ffffffff)
[ 11.571940] fb0: switching to vc4drmfb from simple
[ 11.572727] Console: switching to colour dummy device 80x30
[ 11.575883] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 11.784159] Console: switching to colour frame buffer device 240x67
[ 11.817465] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 11.817531] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 11.826457] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 11.826520] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 11.831255] pcm512x 1-004d: Failed to reset device: -121
[ 11.832138] pcm512x: probe of 1-004d failed with error -121
[ 11.840319] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 11.840382] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 11.871388] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 12.373216] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 14.368219] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
[ 14.368685] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 14.389275] smsc95xx 1-1.1:1.0 eth0: Link is Down
[ 16.485455] random: crng init done
[ 16.485487] random: 7 urandom warning(s) missed due to ratelimiting
[ 16.486569] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[ 16.486649] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 16.528161] 8021q: 802.1Q VLAN Support v1.8
I’m not certain if this is related, but systemctl status systemd-modules-load.service outputs the following error:
● systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2021-08-28 21:50:35 EDT; 17min ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 229 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 229 (code=exited, status=1/FAILURE)
Aug 28 21:50:35 tv-living systemd[1]: Starting Load Kernel Modules...
Aug 28 21:50:35 tv-living systemd-modules-load[229]: Failed to find module 'snd_soc_bcm2708_i2s'
Aug 28 21:50:35 tv-living systemd-modules-load[229]: Module 'bcm2708_dmaengine' is builtin
Aug 28 21:50:35 tv-living systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Aug 28 21:50:35 tv-living systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
Aug 28 21:50:35 tv-living systemd[1]: Failed to start Load Kernel Modules.
Thanks for reading,
Ian.
