You did not post the information I requested in my previous reply to you.
which clone?
We haven’t removed any kernel modules (you can verify this with diff), but if you see anything that seems amiss just let me know what we need to append in our kernel configuration.
I did find that the patch I needed (proper single FLAC + cuesheet support, finally fixed!) from kodi 16.1Final wasn’t included - OSMC/May update seems to be based from an earlier release candidate
Today I installed fresh 2016.04-1 version, and there is no problem with sound.
I also noticed, that 2016.04-1 version also doesnt have module snd_soc_bcm2708, so this was no issue.
After upgrading to May 2016.05-1 - sound dissapear. http://paste.osmc.io/befumelufu
All of the failing HifiBerry’s are using the same overlay - hifiberry-dac. I modified all of the soundcard overlays last week to allow dynamic loading and unloading, but in doing so I broke the hifiberry-dac version - sorry about that. I fixed it the next day, but @sam_nazarko was unlucky enough to get the bad one. You may be able to patch up your system by downloading this fixed version and overwriting your installed copy, otherwise I’m sure the next release will no longer have this problem.
