gr33n
29 April 2019 22:02
1
someone else can confirm high CPU usage of the new Kodi ?
11782 osmc 20 0 537904 117216 50568 R 77,9 15,3 17:08.39 kodi.bin
goes from from 44% up to 77%
that’s when im in Main menu oder a Season Folder
In Main Series Folder it goes down to 15%
11782 osmc 20 0 538328 117940 50580 S 18,9 15,4 18:26.32 kodi.bin
restarting mediacenter didnt fix it.
didn’t had that on old Kodi 17.X
Kodi may be performing some migrations in the background
Leave it 25-30 mins to settle.
gr33n
30 April 2019 10:10
3
that would have been to easy
it stays at this levels depending on the menu im idling.
50% right know idling in a Season folder for 8 hours.
I suspect some addons having issues with Kodi Leia. My Pi3b+ idles at 19% CPU.
Propose that you review your current addons and either disable them or do a quick test by moving your running config into a backup folder and restart the mediacenter.
gr33n
30 April 2019 11:23
5
Hi can u tell me what i need to move for testing this out ?
mv .kodi .kodi_backup
And to reverse back
mv .kodi_backup .kodi
gr33n
30 April 2019 11:27
7
thank you and is there some config file where i can see all the addons i have activated ?
It’s in the database so you would need to have a sqlite editor to check.
Alternative a rough picture would be
grep installed .kodi/temp/kodi.log
gr33n
30 April 2019 18:00
9
Well fresh kodi config doesnt help…
as soon as is have scraped something and go into a Season Folder CPU load jumps up.
What skin are you using? Does the issue also occur with other skins?
gr33n
30 April 2019 18:19
11
im using the standard skin … didnt tryd others yet
Well than maybe the problem is outside of the Kodi config. For that case only a clean reinstall could solve it.
But before going that step would suggest to upload some debug logs for review and maybe install htop
to check if Kodi is the CPU hook and also can see if all 4 cores are high
gr33n
1 May 2019 11:56
13
htop shows 1 core @ 46% in Season folder menu
as soon as i start a movie load drops to 15-19%.
back in Season menu jumps up to 46% again.
That’s totally normal, nothing strange there
gr33n
2 May 2019 11:09
15
Well the old 17 Version was only consuming like 10% idling in the Menu.
Well only can say that CPU usage on both my Pi3 and Vero4K dropped with v18
gr33n
16 May 2019 11:58
17
can i revert back to Kodi 17 somehow ?
ooZee
16 May 2019 12:06
18
You can reinstall using December image, if this is a must.
gr33n
16 May 2019 12:30
19
i thought more like in place … deinstall current kodi version and reinstall 17.
