I would like to know how to play iso files because I cant
As I explained, you need to post some debug logs.
Currently we don’t know if you’re playing encrypted files, whether they’re DVD or BD ISOs or what is occurring when you try to play them.
reproduce the issue
upload the log set (all configs and logs!) either using the
Ok thanks, I will try to play an iso file and put the logs
You seem to be trying to stream an ISO from a remote web server
Have you tried local playback to rule out a problem with the stream? Maybe you can try with a local ISO
Yes not playing locally too
I downloaded a small iso test video it’s playing
That tells us then that there is a problem with the other ISO that you are trying to play. Have you tried it on a PC to see if it plays OK there?
Not yet , tried a video and and SCAD iso both were not working on kodi
Is the ISO encrypted?
Is it a 4K BD ISO or from a DVD?
For some BD ISOs the menus won’t work if they are Java but the videos themselves will play.
BD ISOs that are encrypted need some additional steps to get working.
The first one is dvd , the second one is audio album ( it says path invalid or not found)
I cant tell if its encrypted or not sorry
The SACD addon is not one of the default addons available in kodi. You would need to build it yourself. (or convince a dev to build it for OSMC)
I’m not sure about the current status for it, (eg, if it currently actually works for iso images)
note, kodi does play .dsf files by default, so your best bet may be to simply rip the SACDs.
Personally, I rip all my SACDs to flac because that’s just easier to tag with metadata.
I might give a stab at compiling it [for vero 4k] (I’ve got a few other binary addons such as visualizations and some other audio plugins on my repo)
Have you verified that the iso files (from what may be a shady warez http site) are actually legit iso’s? and not malware trojans?
Not verified, both iso files downloaded from different sources, I will try other iso
Thanks for explanation, I don’t have an experience do build addons
If you know if this addon available somewhere please tell me
I’ll include the SACD add-on shortly by default.
Thanks where it will be available?
Under Add-ons.
When the add-on will be available?
