Dear friends,
my Vero2 is rebooting every few minutes (so interrupting anything else I’m watching because of the CEC).
This is happening since yesterday morning there was a power outage (I was at my office) and have found the battery of the UPS flat and had to reset the whole shebang.
So I’m kind of suspecting a physical power problem in either the UPS or the Vero2 power supply.
Is there anything I can explore on the Vero2 logs to try and pinpoint the problem ?
Right now only solution was to physically unpower the unit (because the sudo shutdown -h 0 or doing a power off from the menu leads to a reboot and not to the desired shutdown).
BTW this is not new I must search the site but the screen size is not reported correctly and need to find a way to force it to 1080p
Hi @ActionA thanks for chiming in. On other Linux systems I had, there was a little daemon monitoring the APC UPS data port and you could use its signals to act upon them for example triggering a shutdown when the battery level or time limits you had set expired.
LoginDUPowerSyscall means someone one the system has requested a reboot. That’s why the device has rebooted there. It’s not watchdog (hardware related) or Kodi wouldn’t be aware of the reboot request.
Vero2 does not run nor has anything installed other than OSMC.
Of course the logs have been generated after myself rebooting the system via KODI’s menu and the timestamp is roughly when I did initiate the shutdown manually.
Could that LoginDUPowerSyscall be a product of my shutdown or of some sort of reboot request after an update ?
The shutdown issue which resulted in a reboot has been fixed in this month’s update. A shutdown request will also invoke ‘LogindUPowerSyscall’, as Kodi makes known the user request to power down or reboot the system via systemd’s logind interface.
All your log shows me is that a power cycle / or shutdown was requested, and the system turned off.
You can try a clean install to rule out a problem with the installation.
This is the log uploaded just a few seconds after a SPONTANOUS reboot which happened roughly at my 17:45 (local time 15:45 GMT) with Kodi’s homepage appearing at roughly 17:46
Maybe just reflashing the card and reconfiguring my Samba source, sound settings and stuff would be the best way ?
The installer point to a July installation and to an Android one … which one is recommended ?
What is leaving me puzzled is that until this morning’s power outage poor Vero2 was a faithful dependable friend
I would not have remembered I installed and enabled TVHeadEnd a few days back, so when I stated “the system behaved well until the power fault” I was not complete nor totally correct !
I have uninstalled TvHeadEnd from OSMC’s app store and will see if that fixes the glitch.
Thanks a bunch.
PS BLUSH … where is the SD card in Vero2 ??? I can’t seem to see a slot from which I could have inserted a new SD card. Is it inside ? In case I’d need it in the future a Sandisk 8GB SD (not microSD) would be a wise choice ?
The internal storage in the Vero 2 is a NAND chip. You can’t remove it, it’s soldered to the board.
It has an SD card slot on the side, which you can use to reflash the internal storage, and boot Android off an SD. You can put a full sized SD card in the side.
