First make sure Docker is installed.
curl -sSL https://get.docker.com | sh
It’s also useful to add the current user to Docker group to avoid having to use sudo in front of every Docker command.
sudo usermod -aG docker $USER
Then we simply need to create the systemd file, enable, then start it. Using your favourite text editor create a systemd service file;
Check out the config here; https://hub.docker.com/r/lsioarmhf/couchpotato/
sudo vim /etc/systemd/system/couchpotato.service
[Unit]
Description=Couchpotato container
Requires=docker.service
After=docker.service
[Service]
Restart=always
ExecStart=/usr/bin/docker run --name=couchpotato -v /opt/couchpotato:/config -v /mnt:/downloads -v mnt:/movies -e PGID=1000 -e PUID=1000 -e TZ=UTC -p 5050:5050 lsioarmhf/couchpotato
ExecStop=/usr/bin/docker stop -t 2 couchpotato
ExecStopPost=/usr/bin/docker rm -f couchpotato
[Install]
WantedBy=default.target
Now enable the service;
sudo systemctl enable couchpotato and then start it with sudo systemctl start couchpotato
You can check it with sudo systemctl status potato
Just open a browser on any device in your network, type in the IP address with port 5050
e.g. 192.168.1.100:5050
