Hello
I’m learning to live with the new Vero 4K+
I’ve learned that its conception was to run all the time and never stop as a server.
In my configuration, I have three devices connected to an HDMI switch with auto switch function (OCTAVA switch):
Bluray player
Vero4K+
ATV4K
The switch works with two rules:
priorizes top devices in the list
when an “higher ranked” device stops emitting HDMI, switch to first device following.
When I turn the Blu-ray off, it switches to Vero4K perfectly.
But how can I switch from the Vero to the ATV ?
Sleep mode is not enough as HDMI is not inhibited, preventing from autoswitching.
If I turn it down from Kodi, it’s OK… but then I have to go to the unit and unplug it to restart.
I’ve read solutions with Smart electric adaptors.
Any thing else to suggest ?
Unfortunately not.
When I put it in standby, the screen is black but it doesn’t vacate the HDMI port.
Only if I turn it OFF, will the HDMI port vacate and auto switch work.
In the other thread, Sam speaks about HPD Lock mode. do you know what it is ?
That is for not reporting HDMI changes to the Vero.
My TV reports “no signal” when I enter standby.
Suggest to upload logs to check why yours may not do that.
I think that my switch refuses to vacate a port as long as some current remains.
It seems that when StandBy, the Vero doesn’t output any signal through HDMI, but it must remain some power.
I tried to change the order of the devices connected:
1/ Bluray
2/ ATV
3/ Vero
And I have the exact same problem.
When I ask the ATV to go to stand by, the Octova doesn’t switch to 3/VERO. In the same way, the ATV must maintain some power, although no video signal is detected by the projector.
I’m thinking about installing a Homekit plug. It would allow to turn the power of the Vero on and off remotely.
Hence my question: is there a risk to shut down the vero only by removing power from it ? Is it necessary to turn it down through Kodi first ?
The risk of software/system corruption is significant if you don’t shutdown first. You might be able to get away with it for a period of time but this would not be recommended unless you happened to enjoy reinstalling and reconfiguring your system.
