[HOW-TO ] retrOSMCmk2: a RetroPie installer on the Vero4K
Just wanted to note, installed onto my vero 5 a couple months ago without issues and emulation support has been far better than on my vero 4k - the N64 emulators work much better and I can run Dreamcast games!
Thank you for the continued maintenance of this script
I hope the stability remains after the move of OSMC to the new kernel in a few months
Any idea about this problem ?
Sine you are runnig sudo, my guess is that there might be another problem creating that folder/firectory. Like if you have run the setup script before and aborted it, it might give a “permission error” even if it’s a conflict error. That is, the folder already exists. Both gives errors and depending on the script, it could have a catch all errors as permissions. I have not looked at those scripts in ages. Check if there already exist a folder called RetroPie-Setup and remove it before you try so run “sudo ./setup.sh” again.
This answer is not researched, but a educated guess.
I couldn’t reproduce the permissions fault. That’s me trying on a clean VeroV install image. So I’m guessing some prior contamination as joakim suggested.
Where it is falling down is on package installation.
Several required Debian packages (gpg, dirmngr, libsvn1, subversion), returning HTTP 404s even though apt-get update succeeds and the package index advertises those versions.
@sam_nazarko
Could this indicate a broader issue with the Debian Bullseye base/repository configuration now that Bullseye LTS has ended?
You can use the archive Debian URLs as a stop gap for now
These packages are installing OK here (i.e. subversion)
If you run sudo apt-get clean; sudo apt-get update, do they install?
They are doing today, thank you. So that’s settled down a bit. Now just registering a:
E: Release file for https://security.debian.org/dists/bullseye-security/InRelease is expired (invalid since 18h 12min 58s). Updates for this repository will not be applied.
Experiencing some other dev package issues as I proceed, which I suspect are SDL2 related. I’m a bit rusty, but will start down the rabbit hole on those. Thanks.
The show stopper currently is that the dev packages cannot be installed because they are older than the patched runtimes. e.g.
apt-cache policy libasound2-dev libasound2
libasound2-dev:
Installed: (none)
Candidate: 1.2.4-1.1
Version table:
1.2.4-1.1 500
500 Index of /debian bullseye/main armhf Packages
libasound2:
Installed: 1.2.4-1.1+deb11u1
Candidate: 1.2.4-1.1+deb11u1
Version table:
*** 1.2.4-1.1+deb11u1 100
100 /var/lib/dpkg/status
1.2.4-1.1 500
On my Vero4k they are in sync.
I see the VeroV sources.list has moved from http://ftp to https://deb
But otherwise comparable.
This should now be solved.
See: OSMC update issues solution
Or help them with simple code for been std lets work
JustSayin zAKA CommonSense
Sorry, I don’t follow. I wanted to give a full write up to what’s happened, but do appreciate the post is extensive.
If you’re still having an issue, the solution is:
  1. My OSMC → Updates → Manual Controls → Apply Hotfix
  2. Enter: updates2026fix
  3. Let it finish, then check for updates or try the App Store again.
This lets it all knsyall yeah ?
Hi Sam,
I had a feeling this was going to be something “bigger picture”. Thanks for getting it sorted. Hotfix applied just fine as per the post.
The needed dev packages are synchronised now and installing as normal.
Regarding the retrOSMCmk2 install issues some have had, I can report that from a clean install my script seems to be running ok. Tested with the “basic install” option and a quick run on the SNES.
Thanks for confirming the hotfix resolved things for you and giving things a quick test.
