UPDATE: you can now semi-automatically install Syncthing.
OPTION1: AUTOMATIC INSTALLATION
This will install SyncThing and configure the mediafolder that will contain the Sync folder.
Download my OSMCautosetup script: wget https://gist.githubusercontent.com/zilexa/7a654cd18c9ec663f4daa1a791a5f99e/raw/be532deec710c2e82a269ec74468603cbb2fdb86/OSMCautosetup.sh
Now edit it, set a 0 for the apps/configurations you don’t want and a “1” for SyncThing, also set the path to the mediafolder/harddrive or network location that should contain the Sync folder, where it will sync your files: nano OSMCautosetup.sh
(save the file with CTRL+O, exit the editor with CTRL+X)
Now run the script: sudo bash OSMCautosetup.sh
OPTION 2: MANUAL INSTALL:
Official information from Syncthing to install on Debian based systems: http://apt.syncthing.net/
This HowTo discusses how to manually do the following (note my OSMCautosetup from option 1 does all of this for you): Installation Autostart on boot Remote WebUI
And will follow the exact guidelines from Syncthing with respect for the file structure and methods used by OSMC.
You can check if Syncthing has started succesfully:
sudo systemctl status syncthing.service
Configuration
7) Edit the Syncthing configuration:
stop the service first sudo systemctl stop syncthing.service
open the config file in the editor: nano /home/osmc/.config/syncthing/config.xml
On line 2, change the following path="home/osmc/sync/" to the default path you want to use. For example in my case, it is my attached USB drive: path="/media/UsbDriveName/"
Also a bit further down the file, change the GUI Listen Address setting from the default 127.0.0.1:8384 to 0.0.0.0:8384. This is required for remote access of the webUI.
Remote WebUI (access Syncthing from other computers)
To access the webui, enter the IP of your OSMC device in a browser, for example: 192.168.1.1:8384
You will never need to do anything via SSH. Everything can be done via the webUI. To access this webUI and any other services like transmission when you are not at home, read my (suprisingly simple!) SSH Tunneling guide. No need to open ports in your router!
You can use for whatever you want. I’m using for synching photos from my phone to external disk on pi. And with cron jobs I have scheduled to organize photos by date and move them into folders by month. So I don’t need to do it manually with connecting it to PC. You could maybe use it to sync two computers or create backups of files from PC to external disk. Use your imagination
Do you have external address or external ip? Try with this if you have port forwarding enabled. I’ve got problems when I setup vpn and only works with external address. Maybe will this be helpfull
Hi, I install Syncthing with that automatic script. Everything install correctly but what to do after that ? web UI don’t work.
After that I try manual installation by ssh on my smartphone, everything goes well and on point 6 when I type: [quote]
sudo systemctl enable syncthing.service
[/quote]
I had messege:
I have no idea exactly what you refer to as your “data” but if you are referring to your Kodi configuration, simply copy your ~/.kodi folder to another device and re-image the card with OSMC. Afterwards, overwrite the existing ~/.kodi with your backup.
