Since Sam and the team have their concerns: Would it be a huge waste of resources to sort of dual boot between retropie and osmc? (and how much space are we talking about?)
I mean, if you had them on different partitions you wouldn’t run into them interfering with each other. You could set it to default to boot OSMC but would you be able to boot to the other os within kodi (and boot back from retropie)
i dont mind wasting my time doing stupid stuff so far it works perfect and im sure that Sam and the gang will work out a solution that works either with Retropie or Retroplayer.
Aslong as i can play now with my wiimotes and do some scripting for fun im good
If anyone is interessed i managed to make PS3 controllers working in this Setup. Let me know and i will provide instructions.
mcobit, i having some issues when quitting Emulationstation, it hangs on black screen and doesn’t get back to Kodi, this only happens if i play at least one game, and then exit. Any clues on this?
That is good, I have never even tried this out because of the lack of a decent way to control it. Due to my refusal to have a keyboard or any wired controller for the Pi.
I would like the instructions posted so I can try out RetroPie on the OSMC. My only other time I tried it was a separate card with a NES controller but only for a day to try then never played again because I hated having to use a 15 foot hdmi cable to put the Pi strung across the room to get it close enough to have the controller plugged into the GPIO pins.
Hi Dishins!
I can get the controller to work via usb but noway to get it connected via Bluetooth. How did you manage it? I tried 2 methods:
run the option “317 Pair PS3 Controller” in the retropie Setup but without any result
run the script manually in console
osmc@osmc:/opt/retropie/supplementary/ps3controller$ sudo ./ps3pair.sh
./ps3pair.sh: line 4: /opt/retropie/supplementary/ps3controller/sixpair: No such file or directory
please note that there are some packages that are already installed by OSMC so you won’t need it.
after that, install rfkill (sudo apt-get install rfkill) and remove the software block that OSMC puts on bluetooth (you can do it also via OMSC interface in MY OSMC.
let me know if you struggle with something in the way and i will help you.
Hi mate,
I followed the guide in your link but encounter several pb. I managed to install all packages but this
E: Unable to locate package bluez-compat
Then
osmc@osmc:~/QtSixA-1.5.1/sixad$ sudo update-rc.d sixad defaults
update-rc.d: error: initscript does not exist: /etc/init.d/sixad
osmc@osmc:~/QtSixA-1.5.1/sixad$ sudo make
mkdir -p bins
g++ -O2 -Wall -Wl,-Bsymbolic-functions sixad-bin.cpp bluetooth.cpp shared.cpp textfile.cpp -o bins/sixad-bin `pkg-config --cflags --libs bluez` -lpthread -fpermissive
sixad-bin.cpp: In function 'int main(int, char**)':
sixad-bin.cpp:84:20: warning: taking address of temporary [-fpermissive]
sixad-bin.cpp:89:18: error: 'close' was not declared in this scope
sixad-bin.cpp:100:20: error: 'sleep' was not declared in this scope
sixad-bin.cpp:109:22: error: 'close' was not declared in this scope
sixad-bin.cpp:117:22: error: 'close' was not declared in this scope
sixad-bin.cpp:140:18: error: 'close' was not declared in this scope
sixad-bin.cpp:144:14: error: 'close' was not declared in this scope
bluetooth.cpp: In function 'void do_connect(int, bdaddr_t*, bdaddr_t*, int)':
bluetooth.cpp:104:30: error: 'close' was not declared in this scope
bluetooth.cpp:110:24: error: 'dup2' was not declared in this scope
bluetooth.cpp:111:22: error: 'close' was not declared in this scope
bluetooth.cpp: In function 'int l2cap_listen(const bdaddr_t*, short unsigned int, int, int)':
bluetooth.cpp:148:17: error: 'close' was not declared in this scope
bluetooth.cpp:162:17: error: 'close' was not declared in this scope
bluetooth.cpp: In function 'void l2cap_accept(int, int, int, int, int)':
bluetooth.cpp:195:26: error: 'close' was not declared in this scope
bluetooth.cpp:201:26: error: 'close' was not declared in this scope
bluetooth.cpp:221:26: error: 'fork' was not declared in this scope
bluetooth.cpp:228:32: error: 'dup2' was not declared in this scope
bluetooth.cpp:229:30: error: 'close' was not declared in this scope
bluetooth.cpp:242:57: error: 'execve' was not declared in this scope
bluetooth.cpp:254:26: error: 'close' was not declared in this scope
bluetooth.cpp: In function 'int l2cap_connect(bdaddr_t*, bdaddr_t*, short unsigned int)':
bluetooth.cpp:274:25: error: 'close' was not declared in this scope
bluetooth.cpp:291:25: error: 'close' was not declared in this scope
Makefile:10: recipe for target 'sixad_bins' failed
make: *** [sixad_bins] Error 1
I tried to run sixad but no success neither:
osmc@osmc:~/QtSixA-1.5.1/sixad$ sudo service sixad start
Failed to start sixad.service: Unit sixad.service failed to load: No such file or directory.
I am not really a Linux user so make the explanations noob proof Thanks.
I got your script working, including the shortcut - great work!! However, I can’t get mame to work. I am using the 0.37b5 rom set, which are in the \home\osmc\Retropie\roms\mame-mame4all\ directory, but the games won’t load. I am getting the following error when trying to run tiger heli for instance:
/opt/retropie/supplementary/runcommand/runcommand.sh: line 671: 743 Illegal instruction /opt/retropie/emulators/mame4all/mame “tigerh”
All my other emulators work fine. Any help would be greatly appreciated!
Thanks dishins for all the procedure!
It worked great until the very last step, when I unplugged the controller, the leds keep flashing and despite all the PS button pressing nothing happens, no way to pair it
7 devices in list
0A12:0001
Nothing found at this address...
Freeing device config descriptor...
Device config descriptor free.
054C:0268
Number of possible configurations: 1
Device class: 0
Vendor ID: 1356
Product ID: 616
Interfaces: 1
Number of alternate settings: 1
Interface number: 0
Interface endpoints: 2
Descriptor Type: 5
EP Address: 2
Current Bluetooth master: 00:00:00:1A:7D:DA
Setting master bd_addr to 00:1A:7D:DA:71:13
Master BD_ADDR set to 00:1A:7D:DA:71:13
Device closed, attempting to flush all busses...
Device class: 0
Vendor ID: 1356
Product ID: 616
Interfaces: 109
Interface number: 0
Descriptor Type: 5
EP Address: 129
osmc@osmc:/opt/retropie/supplementary/ps3controller$ cd /dev/input/
@mcobit As with my earlier post. This issue still exists. If you allow RetroPie to make a shortcut (which you need!) then it breaks the default skin. You cannot use the editor to customise the main menu. I’ve not tried NOT making the shortcut so it is possible some other part of the script is causing this issue but unlikely. I do think we need to be able to customise the main menu. I really want to reduce the number of items on the menu list.
I did a manual edit on Confluence but it operates differently from the OSMC skin and refused to boot if I used the modded Home.XML file so I obv. didnt get that right.
I wish I understood what you were saying. What is this “skin.shortcuts”? Do you mean had I installed using the script generating the shortcut on the default OSMC skin (“yes” I did and “no” it breaks things very reliably).
