Hi there,
Just wanted to explain to you how to install and use qBittorrent on OSMC.
Why qBittorrent? Well, I like it, it’s lighter than Deluge and has more features than Transmission. ^^
First, you need a console/terminal.
You can install the GUI version of qBittorrent like this:
sudo apt-get install qbittorrent
But I prefer the non-GUI version which runs as a deamon (it’s lighter and you can control it with the Web UI). To install it:
sudo apt-get install qbittorrent-nox
To use qBittorrent, you need to launch it manually, like this:
qbittorrent-nox
That’s all. You need to to this everytime you use qBittorrent.
But you can also launch it at OSMC’s startup. It’s not complicated, someone already created a script for this. You can find it here (with detailed explanations).
Here are the principal operations.
Download and install the script with this command line:
sudo wget -O /etc/init.d/qbittorrent-nox-daemon http://launchpadlibrarian.net/38905385/qbittorrent
Modify it with Nano, like this:
sudo nano -w /etc/init.d/qbittorrent-nox-daemon
You need to change the 25th line, like this :
USER=[USERNAME] becomes USER=osmc
Then save the script with CRTL X.
Make the script executable.
sudo chmod 755 /etc/init.d/qbittorrent-nox-daemon
Make sure it is executed on startup.
sudo update-rc.d qbittorrent-nox-daemon defaults
That’s all, have fun downloading. ![]()
Oh and to use the Web UI, you need this:
http://server-ip:8080
Username: admin
Password: adminadmin
