When an updated version of Retropie is released (v3.5 is now out), is the best way to update simply to run the Retrosmc installation script, update scripts, then install retrosmc again? If so, will reinstalling overwrite saved configuration data like controllers, scraped artwork etc.?
When I want to update retropie, I just run the installationscript again with the binaries installation.
It should provide you with the latest version. I once needed to reconfigure my controls afterwards probably because of changes in the mappinghandler. You should keep a backup of your modified config files when updating.
Not sure about artwork though.
Theoretically you could also just run the retropie-setup.sh script from the es retropie menu to update.
@mcobit Thanks for putting this together. It seemed to work fine but now emulationstation crashes when trying to launch from within osmc. The emulationstation splash screen shows up momentarily after which OSMC is relaunched. Before things broke I had:
moved my roms to a different USB drive (and updated symlinks to the ~/RetroPie/roms/ folders)
updated the the system using apt-get update & upgrade
Trying to troublshoot this myself I have a) rerun the binary-based installation via the install-retrosmc.sh script and b) tried to delete ~/RetroPie/scripts/video.sh as per your advice, but the script is not there.
Thanks for the quick reply. I’ve pasted the ES log file below - can’t see anything really wrong with it.
The USB HD is ext4 format, permissions are 777 and the symlinks between ~/RetroPie/roms and the hard disk also seem to be totally in order.
lvl2: EmulationStation - v2.0.1a, built Feb 5 2016 - 01:17:20 lvl2: Creating surface... lvl2: Created window successfully. lvl2: Added unconfigured joystick 小米蓝牙手柄 (GUID: 05000000172700004431000029010000, instance ID: 0, device index: 0). lvl2: Checking available OpenGL extensions... lvl2: ARB_texture_non_power_of_two: MISSING lvl2: Loading system config file /etc/emulationstation/es_systems.cfg... lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/amiga/gamelist.xml"... lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/amstradcpc/gamelist.xml"... lvl1: System "amstradcpc" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/apple2/gamelist.xml"... lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/arcade/gamelist.xml"... lvl1: System "arcade" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atari2600/gamelist.xml"... lvl1: System "atari2600" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atari5200/gamelist.xml"... lvl1: System "atari5200" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atari7800/gamelist.xml"... lvl1: System "atari7800" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atari800/gamelist.xml"... lvl1: System "atari800" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atarilynx/gamelist.xml"... lvl1: System "atarilynx" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/atarist/gamelist.xml"... lvl1: System "atarist" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/c64/gamelist.xml"... lvl1: System "c64" has no games! Ignoring it. lvl1: Unknown platform for system "coco" (platform "coco" from list "coco") lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/coco/gamelist.xml"... lvl1: System "coco" has no games! Ignoring it. lvl1: Unknown platform for system "dragon32" (platform "dragon32" from list "dragon32") lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/dragon32/gamelist.xml"... lvl1: System "dragon32" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/dreamcast/gamelist.xml"... lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/fba/gamelist.xml"... lvl1: System "fba" has no games! Ignoring it. lvl1: Unknown platform for system "fds" (platform "fds" from list "fds") lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/fds/gamelist.xml"... lvl1: System "fds" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/gamegear/gamelist.xml"... lvl1: System "gamegear" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/gb/gamelist.xml"... lvl1: System "gb" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/gba/gamelist.xml"... lvl1: System "gba" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/gbc/gamelist.xml"... lvl1: System "gbc" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/intellivision/gamelist.xml"... lvl1: System "intellivision" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/macintosh/gamelist.xml"... lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/mame-advmame/gamelist.xml"... lvl1: System "mame-advmame" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/mame-libretro/gamelist.xml"... lvl1: System "mame-libretro" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/mame-mame4all/gamelist.xml"... lvl1: System "mame-mame4all" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/mastersystem/gamelist.xml"... lvl1: System "mastersystem" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/megadrive/gamelist.xml"... lvl1: System "megadrive" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/msx/gamelist.xml"... lvl1: System "msx" has no games! Ignoring it. lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/n64/gamelist.xml"...
Running retropie-setup.sh script from ES can (but doesn’t have to) end with problems. ES launched from our launcher doesn’t have properly configured $PATH and ldconfig. I would suggest to use retropie-setup.sh only via ssh. It’s the safest way.
There were other users with a similar problem afaik. I am not sure why this should happen.
The url is reachable and I can download it without a problem on my raspberry.
Do you have VPN activated or custom firewall rules?
Maybe it is only a temporary issue with the github servers.
Please read the first post carefully!
You have to make the file executable before running it.
Also, chances are that the installation will not work as there will be some files that need to be downloaded from github, too.
You can try of course.
