Try to delete or move all controller config files of retroarch. Then create a new one.
I thin they are somewhere in /opt/retropie/config/all
Thanks mcobit. I did a fresh install as I wound up having the same issue with the usb cable connected. Whatever I did put the wired controller in the same situation⦠able to navigate emulationstation, but became unresponsive after loading a game⦠even after a reboot. One thing Iām not sure of⦠if I paired the controller in osmc itself, why does emulationstation want to download a bunch more bluetooth files to be able to pair it in emulationstation? Should I bypass the pairing in osmc and just use emulationstationās pairing? It even shows my controller as already paired if I select to see paired devices, but still wants to install a bunch more files. I did come across something saying I shouldnāt have done a āsudo upgradeā in osmc, and should just use āsudo dist-upgradeā instead. Iāll start fresh once again.
Something I forgot to mention⦠the controller setup screen said it detected 2 controllers, although I only have the one ps4 controller. I thought at the time that it was detecting my keyboard as the second controller, but thatās not the case⦠with no ds4rdrv, it doesnāt detect any controllers. Maybe it had something to do with setting up the controller as wired, then going back and trying to set it up as wireless. The ānot configuredā error I was getting when entering a game, was followed by the āSony wireless controller on port #ā¦ā message. It shouldnāt have made a difference, but thatās the only thing I can think of. Iām about to try this again⦠this time Iāll bypass the wired setup, and just do a wireless setup.
I opened my own thread on thisā¦
Iāve edited the retropie_watchdog.sh script to kill PS when emulationstation launches and start PS when ES exits.
Works great, no need to open a terminal anymore.
great news etienne, can you post your script what you changed thanks
for those who have installed bluetooth steaming ([Deprecated] [TESTING] Bluetooth audio streaming (A2DP)).
Hereās a ānot very prettyā workaround.
FYI, iām not using PulseAudio for anything else than Ad2p audio streaming.
First i made sure that PA doesnāt auto spawn once itās killed
sudo nano $HOME/.config/pulse/client.conf
On my install of OSMC this file did not exist, so i simply added
autospawn = no
Then we want to kill PS when emulationstation is launched and restart PS (so bluetooth streaming works again) when emulationstation exits.
Side note: with this workaround. bluetooth audio does not work in ES, just in kodi.
This can be done many ways. One easy way is to modify the retropie_watchdog.sh script
For my personal pleasure i followed mcobitās strategy and used a variable PULSEAUDIO=1 to easily enable/disable the fix (this adds complexity but only slightly):
sudo nano $HOME/osmc/RetroPie/scripts/retropie_watchdog.sh
To kill PS,add the following lines right after ā. /home/osmc/RetroPie/scripts/retrosmc-config.cfgā:
if [ ā$PULSEAUDIOā = 1 ]; then
sudo killall -9 pulseaudio
fi
To start PS when ES exits, right after the commented line ā#restart kodiā, add:
sudo pulseaudio -D --system
fi
Save the file
Lastly, edit the retrosmc config file:
sudo nano $HOME/osmc/RetroPie/scripts/retrosmc-config.cfg
and add :
PULSEAUDIO=1
Save the file, That should do it.
To disable the fix, just change the variable PULSEAUDIO=0 in the config file
One little warning: it seems like the watchdog script gets overwritten when you update Retrosmc.
Last note: Since iām not using PS for anything else, i did not bother changing back autospawn to yes
Hope this helps
Iāll add that to my script if it is ok for you.
Of course. Iām happy if this helps others.
Maybe leaving autospawn at ānoā can bother other users. In the script, you could create and delete client.conf everytime ES is started and exited.
Just a thought
Iām sorry but i install retrosmc a long time ago and now when i go to update they tell me i have an old raspbian wheezy
Can i update normal through retropie-setup ???
You can try to. But it is better to keep updates relatively frequent to not run into incompatibilities.
Wheezy sound like if you have the old chroot version installed.
In this case, uninstall it from the old install-retrosmc.sh script and then update to the new one and install it.
I install a fresh copy of OSMC, and when install retrosmc, install retropie 4.0.6, after install addon launcher, go to kodi and launch retropie and ⦠returns to kodi and i can not start retropie ⦠¿??
What can i do Āæ??
I uninstall and instal a few times and now its working, i don“t understand but⦠its working again
It might be a problem with your internet connection. Could be that the installer doesnāt finish properly if the connection gets cut during installation.
Hi, thanks for the great script.
two questions.
for update can i use the āretropie-setup.shā and hit āUpdate All Installed Packagesā or will this mess up my osmc install? (also in the second option can i say Yes to kernel update?)
for error/debug log is everything in /home/osmc/.emulationstation/es_log.txt or anywhere else more detail log?
thanks
You can update from the retropie-setup script. This should not be a problem.
Do NOT upgrade the kernel via retropie!
The kernel will be updated via osmcās update functionality.
The es logfile is not the only one.
There should also be a runcommand.out (or similar) file located in /tmp you can refer to with errors with certain emulators.
thanks. might want to add the update info to the FAQ.
Also for debug this helped me.
Run: emulationstation -debug
reproduce the issue and see the error in the terminal
for me it was a non ascii char in a ROM name (720?.nes)
Error was:
Font::readUnicodeChar(const string&, std:size_t&): Assertation ā(c & 0xC0) != 0x80ā failed
see also here. http://blog.petrockblock.com/community/members/dayfather/forums/replies/
That is not really a problem with my scripts
But good to know.
i am having issue with sound. 0 sound in ES, NO pulseaudio
I uninstalled today, and reinstalled, last commit was 18 hours ago, updated script.
any idea?
I have rpi2, latest update for osmc, sound was working in the past, but seems after latest update, i am having 0 luck.
osmc@osmc:~$ head -4 ~/.emulationstation/es_log.txt
lvl2: EmulationStation - v2.0.1a, built Oct 22 2016 - 21:35:15
lvl2: Creating surfaceā¦
lvl2: Created window successfully.
lvl2: Added known joystick Logitech Logitech Cordless RumblePad 2 (instance ID: 0, device index: 0)
osmc@osmc:~$ cat ~/.emulationstation/es_log.txt | grep sound
lvl2: req sound [basic.launch]
osmc@osmc:~$ sudo apt-get remove --purge pulseaudio
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
Package āpulseaudioā is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
osmc@osmc:~$
Is alsamixer installed and volume turned up?
Are you using analogbor hdmi audio?
