@mcobit OK. I understand. Do you know the difference in OS comparing to Retropie distribution for RP3? Is there a way to copy binary from RetroPie image to the OSMC?
You cannot copy the binary. That is the reason why you have to compile from source on osmc.
Edit: It might be an easy fix. But for that you have to contact the retropie guys or the emulator developers.
Edit2: The retropie devs know the difference. OSMC is built for armv7 architecture while retropie image is based on raspian that uses armv6 for compatibility with 1st generation pis.
That is the problem. Some userland libraries in osmc are not compatible with raspbian built binaries.
So thanks for understanding.
I guess this problem can be resolved but you need to be a bit patient. Plastering bold letters around here will not help at all.
It is for focusing on the right things. Somebody enabled this here to be used.
By the way. Can you @mcobit put lr-ppsspp and ppsspp as limitations in scenario on the top of the thread or at github for others to not waste time during installation?
@mcobit Maybe is better to create script that sticks to specific version of RetroPie-Setup that works (not only sometimes). So for me it is better to say people the truth so if this is not working for now, say when it is working and how to install it correctly. For now (current OSMC + latest RetroPie-Setup) it does not work.
@mcobit You donât read my posts. I donât like waste my time doing things that doesnât work. And most of the people like things that works rather than âhopefully will workâ
And you donât read my posts.
I cannot possibly test everything. If you want to help, go ahead. But somebody has to test it to know if it works or not.
I just want to provide something that works and might have some quirks. If you donât want to waist time, donât use alpha or beta software.
I am just sharing what I can achive in my limited freetime with the community.
Edit: You are free to modify my script to pull the release that you want.
Edit2: btw. I am not even using ppsspp so how should I check it is broken in every new release?
That would be waisting my time.
For all of these that has a problem with installing Retrosmc and want to have PSP emulation working perfectly out of the box i recommend following solution:
Perfect scenario is to have following systems on one SD card:
OSMC - media center + experiments with not working software
Retropie - for out of the box gaming experience
Recalbox (optional) - developer version for have PSP working with latest PPSSPP - very good performance
