I’ve got: OSMC + RPi2 + WS2812b. After an OSMC upgrade (not sure what it was exactly but it requested a restart) yesterday, the LEDs just stopped working.
I’ve reinstalled Hyperion, then entire OSMC using the latest version, then using older OSMC images, then different combinations in config.txt … I also checked the leds with arduino and the wiring - they’re all fine.
My wiring setup is: a separate PSU for the LEDs and the RPi, with sharing the LEDs’ ground to Rpi and with RPi’s GPIO18 connected to the LEDs through a small resistor. This had worked since September…
This issue will be resolved in the next kernel update Sam forgot some overlays in this month shipment so you can either go back a kernel version or just wait for next version of the kernel or copy the overlay to the folder per instructions above
No change: root@osmc:~# hyperion-remote -a osmc.local:19444 -c white Connected to osmc.local:19444 Set color to 255 255 25
BTW, I’ve got an arduino at hand if you have an idea on how to use it to test the RPi’s GPIO output…
Is it possible to install packages as of some date? Like I could install an older OSMC image and update the packages up to some date? This way I could update the packages in a controlled way, so we’d be able to see which update exactly breaks it.
its not OSMC thats causing your issue since the software per say forwards the signal without issues and dtparam is enabled in config my guess is that the cables are not correctly connected or loose or even faulty cause the software does what its supposed to.
No, the cable are all fine: I switched the cables from RPi pins to arduino’s and was able to light the LED’s all correct using Adafruit’s NeoPixel library.
It might be RPi PWM ‘hardware’ that is faulty - I don’t know how to check this alone. Still, it’d be quite a coincidence that the LEDs stopped working after the latest upgrade
I’ve managed to get the LED’s blinking using a custom library (instead of Hyperion) - it worked!
All the hardware is correct - there is a bug in the software… somewhere
This I’m not sure of but I guess that if OSMC were trying to use the analog audio, then I wouldn’t be able to use it for driving the LEDs with a different tool (not Hyperion).
I’m not using OSMC but Openelec with the same hardware. Used a RPi 1 before with working Hyperion “out of the box”.
After switching to Rpi2 the same hardware didn’t work any longer. I did a nightmare of a search at Google and found a solution.
The problem really is PWM. There is thread about the problem and finding a solution. A working version of hyperiond is linked there but I can’t find the right posting. The hyperiond was the only file I replaced in a standard hyperion installation to get it work. The config of hyperion has to be changed slightly.
In the sources of hyperion the RPi2 support for WS2812 is included, but you have to compile it with the relating compiler switch.
