i was using this information
OK
root@osmc:~# echo “deb [arch=armhf] https://dev2day.de/pms/$(lsb_release -cs) main” | sudo tee /etc/apt/sources.list.d/pms.list
-bash: lsb_release: command not found
deb [arch=armhf] https://dev2day.de/pms/ main
getting this error regularly
please suggest what should i do?
thank you
yogesh aggarwal
i am also not able to install any other app as it says source not found?
not able to install plex server at all how to do it rest become normal after restart
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
You can run the following instead:
echo deb [arch=armhf] https://dev2day.de/pms/ stretch main | sudo tee /etc/apt/sources.list.d/pms.list
but you’ll also need a key for the repo and, since it’s using https, you’ll need to install the package apt-transport-https
Edit: I forgot to add that running a Plex server on an OSMC Raspberry Pi is not a great idea. Generally, a Plex server needs to be quite powerful.
