My goal was to stream videos and music from my WD My Cloud, bluetooth smart phones, iPads, iPod touches, El Capitan macbook air, youtube, Netflix (not working yet). I got most of options I wanted working solidly. I’m going to share how I did it just in case someone wants the same thing.
- Install Raspian and OSMC from Noobs 1.7 on 32GB EVO class 10 MicroSD card (class 10 is fast). Must have ethernet internet connected, if not you won’t see OSMC option.
- Buy USB mini wifi dongle (I used the old one DWA-131), Bluetooth 4.0 SMK dongle and external USB 3.0 4-ports hub. MicroUSB power, 1A is efficient, I use iPad power block and an old ipod hard drive block also.
- I use my old RF ATI remote wonder and Rii Mini FAVI FE01-BL and Sybu Kodi for iOS as remote control.
- HDMI cable and 4-pole Composite (this one is hard to find) for my Audi MMI integration.
Installation:
Everything is straight forward except some special things need to be done: Youtube, Bluetooth A2DP, Composite Output instead of HDMI.
- Youtube, version 5.1.17 is the correct one to get it working - must log in 2 times from Youtube account.
- Bluetooth Pairing A2DP : follow the instruction here, but some steps need to be modified.
*Add a line dtparam=audio=on in the OSMC config.txt file. Do not create audio.conf file as in the instruction.
*Add these lines in the main.conf
[General]
Enable=Source,Sink,Media,Socket
HFP=true
Class=0x20041C
Name = osmc
*Important thing is to pair with all your devices using “bluetoothctl”. Follow the instruction on that page. or watch this youtube video.
- For Composite to work instead of default HDMI, these lines must be added to the OSMC config.txt
hdmi_ignore_hotplug=1
#hdmi_force_hotplug=1 (# is to comment out)
sdtv_mode=0 (0 is for NTSC).
- The cable must be configured correctly for Raspberry Pi, not all 4-pole on Ebay or Amazon will work. Find an old video Camera cable, it may work with some modification.
- Add wd my cloud media server.
- If you have an external USB hard drive attached to the USB port, you can connect using NFS which is faster.
- If you have username and password, you must use SMB to connect.
- If you change the network name, you can see all share files on the network.
- For NFS just add the ip address.
- For SMB just open the network folder and add with username and password.
For pictures and videos go here.
Cheers,
Louis
