Idiot mode
I’m coming from using a WDTV (Western Digital) playback system. It’s fairly idiot proof. Meaning, my wife can manage the menus.
I can’t do that with the Vero 4K out-of-box.
I would like to know if there are “profiles” that can be selected to allow for basic operations. Mainly, select video’s, select source (NAS), select folder that contains the media, select the media.
Another nice thing would be auto media library refresh built-in. I tried using the add-on Library Watchdog, but it fails at launch. WDTV would refresh from NAS when you changed directories by default.
I like that the Vero4K is open to customization. Maybe this is more than I actually needed.
I know, two issues here. But, should be covered by the subject as one.
Jack
Are you using attached or network storage?
Network filesystems don’t support inotify, so it’s impossible to know ‘when’ to initiate a library re-scan most of the time.
I use source “media server” on WDTV. Then select the NAS.
It’s just polling the NAS at a very frequent interval.
I don’t know what to do with that statement.
WDTV updates the list when you access a directory. Like windows will show the current contents of a directory if you list it.
If Watchdog is the answer, then I need help with why it is failing when it is started. Most likely, I’m setting up the paths incorrectly. Is there anything I should collect to help with debug?
Thanks!
Jack
If you are just accessing paths and not using library mode, then the watchdog is not necessary
If you have set up a library source (video, music, etc.), and you are having issues with Watchdog, you might try the “Library Auto Update” add-on. It only does library auto update, and not generic tasks, so it’s simpler to set up, with less chance of failing.
I remember having problems with the watchdog myself (and the library auto update) and looking for another solution. For years I used the emby server has backend for my library, but somehow this made my system more brittle and my wife less happy, so I went with a kodi only solution and, as you noticed, the library needs more TLC because it doesn’t update on his own.
I ended up using this script:
and having a bash script that runs every few minutes with these two lines:
 python /home/joy/scripts/texturecache.py vscan
 python /home/joy/scripts/texturecache.py vclean
I’m sure that the watchdog can work as well, but this has been very robust so far. Runs in background with no notifications.
I don’t know what to do with that statement either. Do you mean it should behave as I expect without an add-on?
Is there a link to a tutorial that shows how to access the Vero4K and how to add those statements? I’ve tried using ssh2, but I had trouble with what encryption it used.
See Accessing the command line - General - OSMC
I sense the replies you are getting are missing the target. You may find this useful:
You can set the library to refresh at startup but that needs an occasional re-boot.
