Hello, i need to change my static ip on wired connection but i cannot do it:
If i try to do it from the UI when i click apply the old configuration come back;
if i try click on dhcp it do nothing;
if i try to use conman it say the eth device is not supported.
if i change the conmann configuration on /var/lib/connmann/ethernet_macaddress_cable it reset on reboot and do nothing.
I cannot change the router configuration because it’s not mine.
What can i do more?
Is the device up to date? Some logs would help
yes it is, to be honest i’m not sure about how to make logs, can you help?
Can i use this istructions How to submit a useful support request whit eth only then switch to wifi to get the url?
I got a problem in wifi too because i don’t see my wifi wlan, i need to use the other router,the same of the dhcp and internet, with a wrost signal , i don’t know why.
Yeah follow log part and add too here added logs in relevant information
i cant upload the logs from osmc, i don’t know why.
I found this 2 logs, hope it can be helpful.
Upload Files | Free File Upload and Transfer Up To 10 GB for uploadlog.txt
Upload Files | Free File Upload and Transfer Up To 10 GB for kodi.old.log
There are some weird things, for example i cannot ping the raspberry connected with wifi and i cannot log on ssh.
If i use the cable i can do it but i need to change the ip of my computer because it is on a different net
PS: i upgraded the log’s links
The File says it is deleted.
suggest to check if other changes on the SD Card survive a reboot.
Use nano /home/osmc/test.txt and add some text (CTRL-X to end). Reboot and run again the nano command to check if the file still include the text.
i’m sorry, there are 2 new links
The file still there after the reboot
Can you upload full logs via My OSMC? You can save the logs to /boot if there is no connectivity.
Hello, thanks for the help, it is not the uploadlog.txt? I can try again tomorrow
I found the time to try again the process for logs, this time worked.
https://paste.osmc.tv/fuqejazoja
i tryed to change the ip of enxb827eb3e53f7 from 192.168.1.100 to 192.168.179.100 and the gateway form 192.168.1.1 to 192.168.179.1 but when i click apply it reset
Are you using a DHCP server on your local network ?
Yes there is one on a router not mine.
I can’t switch to DHCP, it do nothing on wired connection.
Well if this router is active with a DHCP server (which assigns IP addresses to devices with a MAC address) then it will be assigning its own IP Addresses, which will over ride any you may set manually on the vero/osmc.
So to set them manually you will need to disable this DHCP server on the router. Why do you need to change the IP addresses asignments anyway ?
Have you tried a different ethernet cable or plugging it into a different location to rule out an issue with your physical connection?
The problem is that the router is on another network, the ip of osmc Is manual on 192.168.1.100 but I need to change IP in 192.168.179.100 to go on internet .
If I try to go with DHCP it stay on manual, if I change IP it reset on apply.
Actually no, because I used every time this port. I changed cable without any different behaviour. I’ll try tomorrow to change port.
Did you try using an internet proxy server ?
i tried different cable and different port but it is the same, i can’t use dhcp or change the manual configuration writed some time ago
No, but i can’t cange ip and gateway so i can’t go on internet with cable, anyway if i change the ip of my computer i can enter the rasp with ssh and do things, so the ip + eth is working.
For now i use the wifi that’s work but the signal is low.
I’m starting to thing about format everithings ![]()
