x_pert
3 December 2021 18:58
#1
since update to 19.3 my Harmony don’t work reliable with the internal IR.
This issue is only on live TV and recordings from TVHeadend. I have to press the play, stop, skip, fast forward button a very long time to get a reaction.
If I playing files from NAS (nfs) all works fine.
Anyone the same behavior?
Probably related to the issue discussed here…
Just got a Vero 4K+ and trying to get it to work with my Logitech Harmony 665 IR remote. It looks like I am running the August 2021 2021.08-1 build on the Vero.
I configured the remote to act like an xbox 360 remote and set the remote type in osmc to xbox360-lircd. The remote appears to work ok in all the menus but as soon as I start playing a video (over UPNP if it matters) the remote stops working. The remote that comes with the Vero does not have this issue (it works all the time). If I …
We’re aware of this issue. It’s on the list and you’ll get an update to this thread when it’s been looked in to in more detail.
x_pert
4 December 2021 12:05
#4
Hey, yes it sounds like the same issue. I still wait. Thx for replay and have a nice weekend.
