Hi All!
I’m using raspberry PI as a media center and a universal remote for the home theater, which sends IR signals to the AV-receiver and TV. On raspberry PI 1 with raspbian all worked well.
Now I want to configure the same on raspberry PI 2 with OSMC version 4.1.3.2. The “lircd.conf” file I have downloaded from my RPi 1. When I try to send an IR signal, an error occurs:
sudo irsend SEND_ONCE Philips_PFL Power
irsend: timeout
There is “pin gpio_out_pin=10” set out in “/boot/config.txt”, because i’m using this pin. In fact, the same problem occurs when using the default configuration (pin 17).
Please, help! What i’m doing wrong?
