Oh, I missed that you are doing this remote!
can you install vnc on kodi?
Yes,
thanks,
so are these commands 100% safe?
sudo apt-get update
sudo apt-get install libvncserver0
sudo wget https://github.com/samnazarko/vnc-vero3/raw/master/aml-vnc -O /usr/bin/aml-vnc
sudo chmod +x /usr/bin/aml-vnc
somone else is mentioning
sudo apt install libvncserver1
sudo wget https://github.com/zjoasan/vnc-vero3/raw/master/aml-vnc -O /usr/bin/aml-vnc
aml-vnc
thanks
That version has mouse support. Both should be fine but try the second one first.
reinstall of the plugin solved the issue. thanks
