As above you can see that it should be working now if you run the latest version of the script. Except for a few RPi4 users finding they must install the RetroPie gpg keys manually.
thanks my apologies that I couldnāt find our PMs I am still a bit new to the site thank you for updating this piece of software I will be testing it shortly
hi I had the same issue with gpg keys and found this did work
sudo gpg --keyserver keyserver.ubuntu.com --recv-keys DC9D77FF8208FFC51D8F50CCF1B030906A3B0D31
IDK if it would be good to add this to the script as the key might change
I did find that post when I was trying to debug the issue for you all. Their issue highlighted a port problem. They changed protocol in the script and that was the end of it.
My point is, the command is already in the RetroPie-Setup script. What is unclear is why, on your platform, you have to run it manually.
Edit: All good! Itās working for now. Just trying to figure out how to connect bluetooth gamepads now
Iām a relative beginner at all of this, so forgive me if this is a dumb answer butā¦
I followed this thread to get retrosmc installed on my RPi4 and, at the manual gpg command that @sulti and @thedigi321 suggest, I discovered that OSMC did not have gpg installed on it. Once I installed that, the manual command worked and RetroPie is now working (albeit slowly and laggy with the same V3D IDENT0 error that @sulti mentions)
Could it be that your code just needs another line to install gpg first for the RPi4?
Iām having the exact same problems with the lag and Couldnāt get V3D IDENT0: No such device
Did you have any luck finding a fix?
Unfortunately no.
Eventualy I came with solution based on PINN (GitHub - procount/pinn: An enhanced Operating System installer for the Raspberry Pi) which allowed me to partition my SD Card: I have OSMC on one partition and Batocera (for gaming) on another.
I did some tinkering and I have āGAMESā option in OSMC menu, which changes PINN autoboot partition value and then reboots into Batocera. The same thing on the other side - position āOSMCā in Batocera changes againt autoboot value and reboots back to OSMC.
Post logs - we should be able to find the issue.
Iāll have to have another go because I borked mine trying to fix it.
Do you think it could be a 64 vs 32bit thing?
No idea without any logs.
Hopefully I have done this right.
So rebuilt to pretty much where I was before. Still the same thing. The Emulationstation log is just your normal loadining of games lists etc.
Same here. Iām running RetroPie on RPI4 with OSMC 2021.11-2, and seeing exactly the same error:
Couldn't get V3D IDENT0: No such device
on every launch from Emulation Station. The Emulation Station itself is quite laggy, comparing to the similar setup on RPI3 running from RetroPie image.
While Iām having both boxes configured and reachable, Iād be glad to follow any guidances in order to find the root cause of the issue with video lagging.
Iām not familiar with RetroPie good enough in order to spot a place (or places) to collect any logs, so highly appreciate any advices here.
UPDATE: uhmm:
top - 21:33:41 up 4 min, 1 user, load average: 3.76, 1.93, 0.78
Tasks: 153 total, 1 running, 152 sleeping, 0 stopped, 0 zombie
%Cpu(s): 91.0 us, 2.9 sy, 0.0 ni, 6.2 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
MiB Mem : 3794.0 total, 3312.7 free, 147.4 used, 333.9 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 3569.5 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
713 osmc 20 0 214488 86072 42048 S 367.9 2.2 12:13.22 emulationstatio
743 osmc 20 0 9768 2744 2204 R 1.9 0.1 0:00.04 top
Emulation Station is eating all the CPU cores doing something. Nothing major in logs though:
osmc@rpi4-osmc:/opt/retropie/supplementary/emulationstation$ cat /opt/retropie/configs/all/emulationstation/es_log.txt
Dec 19 21:30:28 lvl2: EmulationStation - v2.10.0rp, built Dec 19 2021 - 10:54:44
Dec 19 21:30:28 lvl2: Parsing XML file "/opt/retropie/supplementary/emulationstation/resources/mamenames.xml"...
Dec 19 21:30:29 lvl2: Parsing XML file "/opt/retropie/supplementary/emulationstation/resources/mamebioses.xml"...
Dec 19 21:30:29 lvl2: Parsing XML file "/opt/retropie/supplementary/emulationstation/resources/mamedevices.xml"...
Dec 19 21:30:29 lvl2: Creating window...
Dec 19 21:30:30 lvl2: Created window successfully.
Dec 19 21:30:30 lvl2: GL vendor: VMware, Inc.
Dec 19 21:30:30 lvl2: GL renderer: llvmpipe (LLVM 7.0, 128 bits)
Dec 19 21:30:30 lvl2: GL version: 3.1 Mesa 18.3.6
Dec 19 21:30:30 lvl2: Checking available OpenGL extensions...
Dec 19 21:30:30 lvl2: ARB_texture_non_power_of_two: ok
Dec 19 21:30:31 lvl2: Loading system config file /etc/emulationstation/es_systems.cfg...
Dec 19 21:30:31 lvl1: System "atari2600" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "arcade" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "atari5200" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "atari7800" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "atari800" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: Error - folder with path "/home/osmc/RetroPie/roms/channelf" is not a directory!
Dec 19 21:30:31 lvl1: Error - folder with path "/home/osmc/RetroPie/roms/coleco" is not a directory!
Dec 19 21:30:31 lvl1: System "atarilynx" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "coleco" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "channelf" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "fba" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "fds" has no games! Ignoring it.
Dec 19 21:30:31 lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/gamegear/gamelist.xml"...
Dec 19 21:30:31 lvl1: System "gb" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "gba" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "gbc" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "mastersystem" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: Error - folder with path "/home/osmc/RetroPie/roms/msx" is not a directory!
Dec 19 21:30:31 lvl1: System "megadrive" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "mame-libretro" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "msx" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "n64" has no games! Ignoring it.
Dec 19 21:30:31 lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/nes/gamelist.xml"...
Dec 19 21:30:31 lvl1: System "neogeo" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "ngp" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "ngpc" has no games! Ignoring it.
Dec 19 21:30:31 lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/retropie/gamelist.xml"...
Dec 19 21:30:31 lvl1: System "pcengine" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "psx" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "sega32x" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "segacd" has no games! Ignoring it.
Dec 19 21:30:31 lvl2: Parsing XML file "/home/osmc/.emulationstation/gamelists/snes/gamelist.xml"...
Dec 19 21:30:31 lvl1: System "sg-1000" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "vectrex" has no games! Ignoring it.
Dec 19 21:30:31 lvl1: System "zxspectrum" has no games! Ignoring it.
UPDATE 2: I have enabled āshow FPSā in ES settings and Iām seeing that FPS is around 6.8-7.2 which is quite low. Perhaps something wrong with video driver / renderer?
I think itās just a by product of OSMC being based on a newer base. Retropie hasnāt caught up and isnāt optimised.
I did have a thought last night though. I remembered the original Retrosmc at one time ran chrootād .
I havenāt got enough experience of doing that though to know if doing that on a Pi4 would fix the issue.
Well, both based on Debian 10 ābusterā. OSMC uses its own kernel though.
Possible way to go would be set up Retropie running on exactly the same hardware box and compare its behavior. I donāt think Iāll have enough time to participate into that, but Iāll definitely provide an update if/when Iāll find anything on this topic.
In the meantime Iām open to any advise on what could I obtain on running installation of OSMC+retropie on the single box in order to help troubleshoot the issue with CPU hog in ES.
OSMC though is 64bit and RPie is still 32bit.
I believe and willing to be corrected there are a few drivers different between the two that RPie doesnāt cope well with the 64bit ones.
If you set up a fresh RPie on the same hardware it will obviously be on the base OS itās optimised for and will play nicw.
I had both running via PINNs until the Memory card decided to crap out. Havenāt bothered to go back and rebuild it yet.
Thatās not correct. All userlands are armhf (32 bit)
Really?
How come uname -m says aarch64?
The kernel is 64-bit on some devices, but the userland is armhf.
Hi All! Unfortunately I have still the V3D IDENT0 error (and very low FPS in emulationstation) with the latest OSMC and Kodi 19. Anyone had solution for this?
