Issue with OSMC since December 2015 update
The kernel is version 4.3.3. Click on any of my favourites would cause the working sign to stay on for quite sometime. When it shows the listing of streams it lags and does not play. It happened only recently after the update.
I have turned on the debug and I have uploaded the logs via the Log uploader. http://paste.osmc.io/ufekaqaxix.
Hope you can help. Let me know if there anything else that is missing from the load files.
Thank you.
Prema
I have edited your post because it mentioned a pirate addon. We cannot provide support for these. To get a better idea of our piracy policy, please see this link here FAQ - OSMC Forums
Sometime you will find that addons both, legal and illegal, can conflict with each other. Occasionally one addon will use older dependencies. This can cause all sorts of symptoms. Problems seem more more common with Program add-ons.
On the other hand, official addons from the official kodi repository usually are updated in a controlled way and are MUCH less likely conflict with each other.
To test streaming funtionality I’d disable, or preferably remove the addons you mentioned and test one of the streaming addons from the official Kodi repository.
If streaming work fine, then it’s likely a server connection speed issue or a problem with the addon itself.
Each addon has it’s own developer. Contact them for support with their addon.
I have installed the Addon Installer from http://fusion/tvaddons.ag/ and installed 1Channel and Dramago. I am not too sure which one is a pirate addon. If you could highlight I would remove that addon.
Thanks.
I have unlisted the thread now as we are looping around the piracy issues which would be a tricky issue as we wouldn’t not name specific piracy approaches in our forum.
I guess our piracy policy with some common sense would answer the question.
hmmmm
NOTHING from fusion.tvaddons.ag will be supported here.
We respect Kodi’s own piracy policy
http://kodi.wiki/view/Official:Forum_rules/Banned_add-ons
