I am having issues with resume function of partially played video’s.
MKV’s are resuming fine, but when I resume a TV recording (DVDLink) it always starts at the beginning even if I choose to resume from a certain point.
Not sure if this is a issues with Kodi or DVBLink, but can you please look into this?
If a log file is needed, please let me know.
Hi for TV watching & recording I am using the DVBLink / TVMosaic add-on indeed. But with previous version of software for the Vero 4K+ everything is working oké concerning resume and the add-on hasn’t been changed in between.
It was working with the previous official (January and before) Vero release and is still working with the test release for MVC 3D. I didn’t try the (3D) version with the new kernel yet because of the issues, so still running previous MVC 3D test release on the Vero in the cinema room. The Vero I am using in the living room is running latest official release software and is having resume issues.
I first start a MKV file stored on network which resumes fine. Secondly I start a DVBLink recording which start from beginning with resume instead of around 50 minutes into recording.
Yes sure, but the MKV is working fine on the network. The issue is with the DVBLink which creates a TS file. Still needed to try the MKV local or do you mean the the TS file?
Well as I wrote for me it looks like Kodi tries to resume but the source seems not be able to skip to the position.
Maybe try to copy the TS file to the Vero and try if it then works that could give more ideas.
But it has been working till previously official version and Kodi 18.6 from Windows desktop is also able to use the resume point. I will upload another log when playing local file.
Just wondering if this issue can be solved? I have read other posts with similar issues, so I am not alone :-). As I already mentioned this is only an issue with OSMC. Kodi from Android or Windows are working fine with resume function of video’s.
Hi Sam, no sorry I am not aware of a staging repository for this purpose unless you mean the beta for the new kernel which I am using on one of the Vero’s I have. So if you want me to test something else, please let me know. Great to hear it is solved already :-).
