H.265 HLG 3840x 2160, 25fps, 18Mbps file is not playing smoothly and slight lip sync issue. File is on usb3 connected HDD (I can send files at 100Mbps to the drive consistently so I don’t think its anything to do with the drive or connection.
I have taken 50hz off the whitelist and it’s much better, I have seen this before for some reason the VeroV doubles the refresh rate and causes problems
This maybe related:-
Try updating to staging.
Regards Tom.
Updating to staging??
Hopefully the issue is now addressed.
- Login via the command line
- Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list - Go to My OSMC → Updater → Manual Controls → and select Check for Updates now. When prompted to do so on screen, please choose to install the update.
- Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
