Hi Graham
Thanks for getting back to me. You can find the full EDID report below.
Monitor Asset Manager Report, generated 2023/10/09
Copyright (c) 1995-2019, EnTech Taiwan.
Monitor #1 [Real-time 0x0100]
** Model name… DELL G3223Q**
** Manufacturer… Dell**
** Plug and Play ID… DEL4284**
** Serial number… 55X70P3-859387733**
** Manufacture date… 2022, ISO week 48**
** Filter driver… None**
** EDID revision… 1.3**
** Input signal type… Digital**
** Color bit depth… Undefined**
** Display type… RGB color**
** Screen size… 710 x 400 mm (32,1 in)**
** Power management… Standby, Suspend, Active off/sleep**
** Extension blocs… 3**
** DDC/CI… Supported**
** MCCS revison… 2.1**
** Display technology… TFT**
** Controller… RealTek 0x2718**
** Firmware revision… 65.3**
** Firmware flags… 0x007445CC**
** Active power on time… 1018 hours**
** Power consumption… Not supported**
** Current frequency… 319,10kHz, 144,00Hz**
Color characteristics
** Default color space… Non-sRGB**
** Display gamma… 2,20**
** Red chromaticity… Rx 0,684 - Ry 0,310**
** Green chromaticity… Gx 0,261 - Gy 0,654**
** Blue chromaticity… Bx 0,142 - By 0,062**
** White point (default)… Wx 0,313 - Wy 0,329**
** Additional descriptors… None**
Timing characteristics
** Horizontal scan range… 30-255kHz**
** Vertical scan range… 48-144Hz**
** Video bandwidth… 600MHz**
** CVT standard… Not supported**
** GTF standard… Not supported**
** Preferred timing… Yes**
** Native/preferred timing… 3840x2160p at 60Hz **
** Modeline… “3840x2160” 594,000 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync**
Standard timings supported
** 720 x 400p at 70Hz - IBM VGA**
** 640 x 480p at 60Hz - IBM VGA**
** 640 x 480p at 75Hz - VESA**
** 800 x 600p at 60Hz - VESA**
** 800 x 600p at 75Hz - VESA**
** 1024 x 768p at 60Hz - VESA**
** 1024 x 768p at 75Hz - VESA**
** 1280 x 1024p at 75Hz - VESA**
** 1152 x 864p at 75Hz - VESA STD**
** 1280 x 800p at 60Hz - VESA STD**
** 1280 x 1024p at 60Hz - VESA STD**
** 1600 x 1200p at 60Hz - VESA STD**
** 1680 x 1050p at 60Hz - VESA STD**
** 1920 x 1080p at 60Hz - VESA STD**
** 1920 x 1200p at 60Hz - VESA STD**
** 1600 x 900p at 60Hz - VESA STD**
Report information
** Date generated… 2023/10/09**
** Software revision… 2.91.0.1043**
** Data source… Real-time 0x0100**
** Operating system… 10.0.22621.2**
Raw data
** 00,FF,FF,FF,FF,FF,FF,00,10,AC,84,42,55,37,39,33,30,20,01,03,80,47,28,78,EA,1E,75,AF,4F,42,A7,24,**
** 0F,50,54,A5,4B,00,71,4F,81,00,81,80,A9,40,B3,00,D1,C0,D1,00,A9,C0,08,E8,00,30,F2,70,5A,80,B0,58,**
** 8A,00,C4,8F,21,00,00,1E,00,00,00,FF,00,35,35,58,37,30,50,33,0A,20,20,20,20,20,00,00,00,FC,00,44,**
** 45,4C,4C,20,47,33,32,32,33,51,0A,20,00,00,00,FD,00,30,90,1E,FF,3C,00,0A,20,20,20,20,20,20,03,7C,**
** F0,02,70,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,**
** 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,**
** 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,9E**
Hardware data
** BUS_SLOT = PCI00000.PCI00004.PCI00008.PCI0000C.PCI00010.PCI00014.PCI00018.PCI0001C**
** 00000000 = 14D81022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000008 = 14DA1022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000009 = 14DB1022.08100407.06040000.00810010.00000000.00000000.00030100.3000F1F1**
** 0000000A = 14DB1022.00100406.06040000.00810010.00000000.00000000.00040400.200001F1**
** 00000010 = 14DA1022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000011 = 14DB1022.00100407.06040000.00810010.00000000.00000000.00110500.2000E1E1**
** 00000012 = 14DB1022.00100406.06040000.00810010.00000000.00000000.00121200.200001F1**
** 00000018 = 14DA1022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000020 = 14DA1022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000040 = 14DA1022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000041 = 14DD1022.00100407.06040000.00810010.00000000.00000000.00131300.0000D1D1**
** 00000043 = 14DD1022.00100406.06040000.00810010.00000000.00000000.00141400.000001F1**
** 000000A0 = 790B1022.02200403.0C050071.00800000.00000000.00000000.00000000.00000000**
** 000000A3 = 790E1022.0220000F.06010051.00800000.00000000.00000000.00000000.00000000**
** 000000C0 = 14E01022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C1 = 14E11022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C2 = 14E21022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C3 = 14E31022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C4 = 14E41022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C5 = 14E51022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C6 = 14E61022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 000000C7 = 14E71022.00000000.06000000.00800000.00000000.00000000.00000000.00000000**
** 00000100 = 14781002.00100407.060400C1.00010010.FCC00000.00000000.00030201.0000F1F1**
** 00000200 = 14791002.00100407.06040000.00010010.00000000.00000000.00030302.0000F1F1**
** 00000300 = 73BF1002.08100406.030000C1.00800010.0000000C.000000F8.0000000C.000000FC**
** 00000301 = AB281002.00100400.04030000.00800010.FCBFC000.00000000.00000000.00000000**
** 00000400 = 52361DBE.00100406.01080201.00000010.FCF00004.00000000.00000000.00000000**
** 00000500 = 43F41022.00100407.06040001.00010010.00000000.00000000.00110605.0000E1E1**
** 00000600 = 43F51022.00100404.06040001.00010010.00000000.00000000.00070706.000001F1**
** 00000620 = 43F51022.00100404.06040001.00010010.00000000.00000000.00080806.000001F1**
** 00000628 = 43F51022.00100404.06040001.00010010.00000000.00000000.00090906.000001F1**
** 00000630 = 43F51022.00100404.06040001.00010010.00000000.00000000.000A0A06.000001F1**
** 00000638 = 43F51022.00100404.06040001.00010010.00000000.00000000.000B0B06.000001F1**
** 00000640 = 43F51022.00100404.06040001.00010010.00000000.00000000.000C0C06.000001F1**
** 00000648 = 43F51022.00100404.06040001.00010010.00000000.00000000.000D0D06.000001F1**
** 00000650 = 43F51022.00100407.06040001.00010010.00000000.00000000.000E0E06.0000E1E1**
** 00000658 = 43F51022.00100404.06040001.00010010.00000000.00000000.000F0F06.000001F1**
** 00000660 = 43F51022.00100406.06040001.00010010.00000000.00000000.00101006.000000F0**
** 00000668 = 43F51022.00100406.06040001.00010010.00000000.00000000.00111106.000000F0**
** 00000E00 = 812510EC.00100406.02000005.00000010.00000001.00000000.FC900004.00000000**
** 00001000 = 43F71022.00100406.0C033001.00000010.FC800004.00000000.00000000.00000000**
** 00001100 = 43F61022.00100400.01060101.00000010.00000000.00000000.00000000.00000000**
** 00001200 = 52361DBE.00100406.01080201.00000010.FCE00004.00000000.00000000.00000000**
** 00001300 = 164E1002.08100406.030000C7.00800010.2000000C.000000FC.3000000C.000000FC**
** 00001301 = 16401002.00100400.04030000.00800010.FC6F8000.00000000.00000000.00000000**
** 00001302 = 16491022.00100400.10800000.00800010.00000000.00000000.FC500000.00000000**
** 00001303 = 15B61022.00100406.0C033000.00800010.FC400004.00000000.00000000.00000000**
** 00001304 = 15B71022.00100406.0C033000.00800010.FC300004.00000000.00000000.00000000**
** 00001306 = 15E31022.00100006.04030000.00800010.FC6F0000.00000000.00000000.00000000**
** 00001400 = 15B81022.00100406.0C033000.00000010.FCD00004.00000000.00000000.00000000**
