You can update them separately and use Trakt to sync watched status. That being said The original RPi IMO is painfully slow compared to newer models and not worth hanging onto given the fairly low upgrade cost.
All RPi’s are going to be partially gimped due to loosing some of the hardware decoding support with the Kodi 19 update. The RPi 4 performs better than model 3 does with Matrix and I’ve not seen any downsides to the upgraded hardware so far.
As someone not native in English but still pretty decent at it I have trouble understanding that statement.
You are saying that all Rpis will lose hardware decoding wich I think is vital because the CPU on most SoCs in this price range is too slow to decode in software.
And then you are saying that Rpi4 performs better with matrix then older Rpis… but what does it perform better considering video playback is gimped due to no hardware decoding?
Due to changes in Kodi there is no more OMX or MMAL support for the RPi. There is new hardware support, but as Sam just stated, their is currently no deinterlacing support in that hardware decoder. With progressive sources my RPi 3 seems to play without issue. My RPi 4 plays the same, but it is a bit faster in the UI, and it adds the ability to play 4K HEVC and do HD audio passthrough. If someone was planning on purchasing a new RPi I can’t think of any advantage to purchasing an older model. If someone was in need of playing progressive sources they would, in my opinion, as of right now, be better off sticking with Kodi 18 or purchasing a Vero.
The only thing worth mentioning here is that HD audio won’t happen until we do a Debian Bullseye (11) release as we need a newer version of libasound. The current Debian Buster (10) version is too old.
I suspect that’s a bit over a year away.
MMAL is still used / supported on these devices, but the V4L2 interface is the direct API used via Kodi. V4L2 is a shim around MMAL.
We need more info to provide an answer. There have been 4 iterations of the Vero. Which one do you have? If it’s a Vero4k or Vero4k+, we’re going to need to see logs or possibly just a screenshot of this (notification?) to understand what you are describing.
My understanding is that you have a Vero 2.
Support for this device is now end of life.
It will stay working and you will be able to download images from Download - OSMC for the foreseeable future, but there is no planned update to Kodi v19 for this device.
The Vero 4K + is the latest model to upgrade to.
There is no immediate need to do so – if your device is still working and doing what you want, then you should just keep using it.
Thanks.
I took a quick look (not installed yet)
Is there a distinct thread on this where I can ask a few questions rather than using this Kodi 19 thread?
No, osmc will probably never support Dolby vision because for that to happen they would need to lock down the device wich goes against the open source philosophy
