Am I the only one that is pissed off with the lack of effort to fix this issue! this is not a new issue. it is making KODI and The Vero4K+ Unusable for me.
having guests over to watch a movie and having audio dropouts in a movie is embarrassing!
That’s the downside of an open source project like kodi. Since all the work is voluntary bugs are sometimes not fixed if none has interest and motivation to fix it
I assume it does not work for DTS-HD MA and DTS:X the same way, cause if you disable DTS-HD passthrough, the device will just send the lossy DTS core instead of decoding it and send it as LPCM.
Is that correct?
Sorry for the confusion.
No high bitrate issues here with DTS-HD MA, but I just wanted to know how DTS-HD MA tracks are handled when passthrough is disabled.
I guess for DTS-HD HRA/DTS-HD MA tracks to be decoded by the Vero, I also have to disable standard DTS passthrough?
In fact, I don’t even have problems with Atmos tracks, at least until now.
But the reason I had to disable at least TrueHD passthrough is because I got a new soundbar and it has a couple of different sound modes, like music, movies, standard etc. but those are not selectable when a Dolby Atmos or DTS:X track is played, because if the soundbar detects a 3D audio track it changes to a specific, not changeable sound mode. The problem with that is, the soundbar seems to lower the volume in loud scenes and for me the movie comes completely unwatchable.
And before anyone asks, yes it has a “auto volume” setting, which is set to “off”. In fact this setting is also not changeable when a 3D audio track is played.
I hope I can return this soundbar.
So that is the reason I asked for DTS behaviour, even though I haven’t tried if this volume lowering problem also exists with DTS:X tracks.
DTS-HD MA should always embed a standard DTS 5.1 stream. If you disable DTS-HD passthrough but not DTS passthrough you will get DTS 5.1 passed through.
