Was trying to upload logs for a different issue and found that I couldn’t use the OSMC tool to upload my logs. Seems to get stuck at ‘Retrieving System’ see screenshot below. I left it there for a few minutes with no progress. Command line tool seemed to stall out too, had to CTRL-C to cancel it, here’s where it was when I did that:
File "/usr/bin/grab-logs", line 893, in <module>
m.launch_process()
File "/usr/bin/grab-logs", line 705, in launch_process
result = self.write_to_temp_file()
File "/usr/bin/grab-logs", line 775, in write_to_temp_file
self.log_blotter = [x.replace('\0', '') for x in self.log_blotter]
KeyboardInterrupt
Any tips on what should do to fix?
PS: FWIW this is running on a Vero 4K (not +)
