There are no other reports of this GPIO message in the log - have you installed any software via APT that could potentially be trying to use the GPIO lines ?
osmc@osmc:~ $ sudo dpkg -l |grep lirc
ii armv6l-eventlircd-osmc 1.1.6 armhf eventlircd for OSMC
ii armv6l-lirc-osmc 0.9.0-5 armhf lirc for osmc
ii armv6l-remote-osmc 1.1.6 armhf Remote support for OSMC, achieved with lirc and eventlircd
osmc@osmc:~ $ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... The following package was automatically installed and is no longer required:
rbp1-image-4.1.2-1-osmc
Use 'apt-get autoremove' to remove it.
Done
@sam_nazarko: It seems it does. I pulled the WIFI-dongle at 16:02 and pushed it back in at 16:12.
See the log below.
Please remember that I have had this dongle for over 2 years. I monitor the logs daily. So, I’m very sure this started after the update of two days ago.
As I mentioned before there’s also a problem with the WIFI. I didn’t want to go into details on that in this thread because I didn’t want to cloud the issue. If this is related I can also lookup parts of the log that show the WIFI problems. There may be some hints in the log linked to below though.
I have the same issue. Just updated and the logs were full of “GPIO_IN=08” and “@@@@- #2 rtw_ps_processor==> rfstate:rf_on”.
After pulling the wifi dongle the logs stop.
I have not released it as an update. I don’t have time to produce a Pi 2 build, so I am waiting for OP to confirm if the issue is gone with the experimental kernel
$ sudo dpkg -i --force-all rbp1-image-osmc.deb
(Reading database ... 26712 files and directories currently installed.)
Preparing to unpack rbp1-image-osmc.deb ...
Examining /etc/kernel/preinst.d/
run-parts: executing /etc/kernel/preinst.d/preprocess-rbp 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
Done.
Unpacking rbp1-image-4.1.3-2-osmc (2) over (2) ...
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
Setting up rbp1-image-4.1.3-2-osmc (2) ...
Hmm. There is a symbolic link /lib/modules/4.1.3-2-osmc/build
However, I can not read it: No such file or directory
Therefore, I am deleting /lib/modules/4.1.3-2-osmc/build
Hmm. The package shipped with a symbolic link /lib/modules/4.1.3-2-osmc/source
However, I can not read the target: No such file or directory
Therefore, I am deleting /lib/modules/4.1.3-2-osmc/source
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
run-parts: executing /etc/kernel/postinst.d/inform-updater 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
run-parts: executing /etc/kernel/postinst.d/process-vmlinuz-rbp 4.1.3-2-osmc /boot/vmlinuz-4.1.3-2-osmc
After rebooting:
$ uname -a
Linux osmc 4.1.3-2-osmc #1 PREEMPT Fri Aug 7 11:03:02 UTC 2015 armv6l GNU/Linux
