Some extra info on the WIFI dongle:
osmc@osmc:~ $ lsusb
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
osmc@osmc:~ $ lsusb
This suggests it is an upstream bug then. It will probably be fixed soon enough.
By āupstreamā do you may kernel or dongle-driver?
Would using the WIFI-dongle from the OSMC-shop āfixā this?
We use the dongle driver from upstream. It may be a better idea for us to use a custom driver instead in the future, but Iāll see if this passes in new kernel releases soon enough.
I do not see this issue with the OSMC WiFi dongle.
@sam_nazarko:
As an experiment I downloaded the latest installer and reinstalled OSMC to a new SD-card.
I then did an apt-get update/upgrade cycle.
The GPIO_IN=08 messages did not return to the syslog.
Theyād been replaced by this trio with a slightly lower frequency:
Aug 14 12:34:11 osmc kernel: rtw_set_ps_mode(): Enter 802.11 power save mode...
Aug 14 12:34:11 osmc kernel: rtl8192c_dm_RF_Saving(): RF_Normal
Aug 14 12:34:11 osmc kernel: rtl8192c_set_FwPwrMode_cmd(): Mode = 1, SmartPS = 2
(see http://paste.osmc.io/yurixufiva)
I then proceeded to update OSMC using itās own updater. This prompted me to reboot.
I rebooted after all updates were done. The log since the last reboot is here:
http://paste.osmc.io/oluwugumac
Note that this has reintroduced the original problem⦠![]()
apt-get upgrade will not upgrade the kernel, if you are updating from the command line you must use apt-get dist-upgrade to do a full upgrade. The OSMC updater does the equivalent of dist-upgrade.
Unfortunately all you have proven is that not upgrading the kernel avoids the problem - but we already know that.
@DBMandrake
To me it also proved that this was not caused by some unknown (SD-card deterioration or other) cause.
As the functionality of OSMC does not seem to be affected and no solution is currently available nor strictly required. Iām willing to mark this issue as closed. Agree?
When you say itās a problem in āupstreamā, where could we file a bug report to get this fixed? Is this Kodi-related or Linux-kernel?
Although I have another wifi-problem recently, but I donāt know if this is related to here so I will start a new topic.
Just received the WiFi dongle from the OSMC-shop.
Here is the log: http://paste.osmc.io/amefunotuk
As you will see the problem has not gone.
Do I need to do something extra?
I seem to be getting this log spam as well and have updated to the August release. It has something to do with the RealTek adapter Iām using since it disappears when I unplug.
July/August updates same thing⦠as an example altho i get GPIO_IN=09
[ 5794.154431] GPIO_IN=09
[ 5794.154457] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[ 5796.154610] GPIO_IN=09
[ 5796.154645] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[ 5798.154571] GPIO_IN=09
[ 5798.154597] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
I am not using any GPIO pins and i have too realtek based wireless dongle
(Using Raspberry PI 2 and dongle is Zyxel NWD2205)
Yeah, there clearly is something up with the wireless networking.
After upgrading to the AUG2015 release I see no change.
What adapter are you using?
From my log:
Aug 31 17:49:41 osmc kernel: smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:
Aug 31 17:49:41 osmc kernel: usb 1-1.4: new high-speed USB device number 4 using dwc_otg
Aug 31 17:49:41 osmc kernel: usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8176
Aug 31 17:49:41 osmc kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 31 17:49:41 osmc kernel: usb 1-1.4: Product: 802.11n WLAN Adapter
Aug 31 17:49:41 osmc kernel: usb 1-1.4: Manufacturer: Realtek
Aug 31 17:49:41 osmc kernel: usb 1-1.4: SerialNumber: 00e04c000001
and
Aug 31 17:49:43 osmc kernel: rtl8192cu driver version=v4.0.2_9000.20130911
and a bit later:
Aug 31 17:49:43 osmc kernel: USB_SPEED_HIGH
Aug 31 17:49:43 osmc kernel: CHIP TYPE: RTL8188C_8192C
Aug 31 17:49:43 osmc kernel: register rtw_netdev_ops to netdev_ops
Aug 31 17:49:43 osmc kernel: Chip Version ID: VERSION_NORMAL_TSMC_CHIP_88C.
Aug 31 17:49:43 osmc kernel: RF_Type is 3!!
Aug 31 17:49:44 osmc kernel: EEPROM type is E-FUSE
Aug 31 17:49:44 osmc kernel: ====> ReadAdapterInfo8192C
$ sudo apt-get install usbutils
$ lsusb
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Realtek device here as well. First line is from lsusb, second is from dmesg.
Bus 001 Device 012: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
[86048.245373] usb 1-1.3.4: new high-speed USB device number 12 using dwc_otg
[86048.347230] usb 1-1.3.4: New USB device found, idVendor=0bda, idProduct=8176
[86048.347268] usb 1-1.3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[86048.347286] usb 1-1.3.4: Product: 802.11n WLAN Adapter
[86048.347303] usb 1-1.3.4: Manufacturer: Realtek
[86048.347320] usb 1-1.3.4: SerialNumber: 00e04c000001
Reinstalled OSMC using my OSMC-shop WIFI-dongle:
From the log:
Sep 06 14:40:42 osmc kernel: usb 1-1.4: new high-speed USB device number 4 using dwc_otg
Sep 06 14:40:42 osmc kernel: usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8176
Sep 06 14:40:42 osmc kernel: usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 06 14:40:42 osmc kernel: usb 1-1.4: Product: 802.11n WLAN Adapter
Sep 06 14:40:42 osmc kernel: usb 1-1.4: Manufacturer: Realtek
Sep 06 14:40:42 osmc kernel: usb 1-1.4: SerialNumber: 00e04c000001
Sep 06 14:40:45 osmc kernel: rtl8192cu driver version=v4.0.2_9000.20130911
Sep 06 14:40:45 osmc kernel: USB_SPEED_HIGH
Sep 06 14:40:45 osmc kernel: CHIP TYPE: RTL8188C_8192C
Sep 06 14:40:45 osmc kernel: register rtw_netdev_ops to netdev_ops
Sep 06 14:40:45 osmc kernel: Chip Version ID: VERSION_NORMAL_UMC_CHIP_88C_B_CUT.
Sep 06 14:40:45 osmc kernel: RF_Type is 3!!
Sep 06 14:40:45 osmc kernel: EEPROM type is E-FUSE
Sep 06 14:40:45 osmc kernel: ====> ReadAdapterInfo8192C
Itās a different pin but the log still fills up with these:
Sep 06 12:50:47 osmc kernel: GPIO_IN=0f
Sep 06 12:50:47 osmc kernel: @@@@- #2 rtw_ps_processor==> rfstate:rf_on
Sep 06 12:50:49 osmc kernel: GPIO_IN=0f
Sep 06 12:50:49 osmc kernel: @@@@- #2 rtw_ps_processor==> rfstate:rf_on
So, no joy with the alternative WiFi dongle, since they are the same chipset.
Iām seeing the same problem on a Pi2 Model B with an Edimax EW-7811Un, which also uses the RTL8188CUS chipset.
Relevant section of DMESG: http://paste.osmc.io/qerokenedo.xml
Same messages on my Raspberry pi2
Hereās the output from lsusb:
Bus 001 Device 004: ID 0846:9041 NetGear, Inc. WNA1000M 802.11bgn [Realtek RTL8188CUS]
and the log messages i get
[238362.911397] GPIO_IN=08
[238362.911431] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238364.911966] GPIO_IN=08
[238364.912010] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238366.911156] GPIO_IN=08
[238366.911184] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238368.911320] GPIO_IN=08
[238368.911344] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238370.911331] GPIO_IN=08
[238370.911364] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238372.911284] GPIO_IN=08
[238372.911317] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238374.911308] GPIO_IN=08
[238374.911341] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238376.911125] GPIO_IN=08
[238376.911147] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238378.911123] GPIO_IN=08
[238378.911146] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238380.911395] GPIO_IN=08
[238380.911427] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238382.911803] GPIO_IN=08
[238382.911845] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[238384.911197] GPIO_IN=08
[238384.911219] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
Today I tried yet another WiFi-dongle I just happened to have lying around
Bus 001 Device 004: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
From the log:
Sep 13 07:53:13 osmc kernel: usb 1-1.5: new high-speed USB device number 4 using dwc_otg
Sep 13 07:53:13 osmc kernel: usb 1-1.5: New USB device found, idVendor=148f, idProduct=3070
Sep 13 07:53:13 osmc kernel: usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Sep 13 07:53:13 osmc kernel: usb 1-1.5: Product: 802.11 n WLAN
Sep 13 07:53:13 osmc kernel: usb 1-1.5: Manufacturer: Ralink
Sep 13 07:53:13 osmc kernel: usb 1-1.5: SerialNumber: 1.0
Sep 13 07:53:16 osmc kernel: ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3070, rev 0201 detected
Sep 13 07:53:17 osmc kernel: ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 0005 detected
Sep 13 07:53:17 osmc kernel: ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sep 13 07:53:22 osmc kernel: ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
Sep 13 07:53:22 osmc kernel: ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.29
With this dongle there are no other related messages filling the log.
This dongle has a different chipset and doesnāt use the buggy RealTek driver.
Going to see how this dongle performs in the long run.
That is a Ralink dongle, and I find the drivers for Ralink to be quite stable.
Think I have worked out the issue in this thread and it should be in for the September update
Hi, I still have the problem. Using an Edimax WiFi dongle. Here is the info:
[2.162165] usb 1-1.5: new high-speed USB device number 4 using dwc_otg
[2.263992] usb 1-1.5: New USB device found, idVendor=7392, idProduct=7811
[2.264038] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[2.264064] usb 1-1.5: Product: 802.11n WLAN Adapter
[2.264089] usb 1-1.5: Manufacturer: Realtek
[2.264115] usb 1-1.5: SerialNumber: 00e04c000001
[5.944173] rtl8192cu driver version=v4.0.2_9000.20130911
and the log flood:
[340.122395] GPIO_IN=08
[340.122418] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[342.122502] GPIO_IN=08
[342.122527] @@@@- #2 rtw_ps_processor==> rfstate:rf_on
[344.122488] GPIO_IN=08
Any progress on the bug fix?
