Hi, I’m trying to connect this (Logitech diNovo Edge old) keyboard to my Vero4K device.
I have paired it in Networking > BlueTooth and it shows up as Logitech diNovo Edge in the Paired Devices
with a blue sign next to it, so it pairs just fine, but when I try to use it (before and after reboot),
it simply doesn’t respond. I have used this many years for my htpc so I know it should work fine.
I have tried:
Pairing it with dongle connected from Networking > Bluetooth
Pairing it without dongle connected from Networking > Bluetooth
The keyboard can likely only be paired with the dongle or another BT device (Vero 4K).
Your answer only adds a spanner in to the works however. When you pair the keyboard with Vero 4K’s Bluetooth; and then exit Kodi, do you have any joy? If not, can you post a set of logs.
10:55 was the time when you uploaded the log.
Might be 10:52 when you plugged in the Logitech reciever
Oct 14 10:52:02 osmc kernel: usb 1-1: new full-speed USB device number 3 using xhci-hcd
Oct 14 10:52:02 osmc kernel: usb 1-1: New USB device found, idVendor=046d, idProduct=c534
Oct 14 10:52:02 osmc kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 14 10:52:02 osmc kernel: usb 1-1: Product: USB Receiver
Oct 14 10:52:02 osmc kernel: usb 1-1: Manufacturer: Logitech
Oct 14 10:52:02 osmc kernel: input: Logitech USB Receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.0/0003:046D:C534.0003/input/input11
Oct 14 10:52:02 osmc kernel: hid-generic 0003:046D:C534.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input0
Oct 14 10:52:02 osmc kernel: input: Logitech USB Receiver as /devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-1/1-1:1.1/0003:046D:C534.0004/input/input12
Oct 14 10:52:02 osmc kernel: hid-generic 0003:046D:C534.0004: input,hiddev0,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1/input1
Well from the logfile not much to find.
I googled a bit and there is a possible power issue, do you by any chance have a powered USB Hub to test with?
Also it seems the keyboard has a full and a HID compatible mode do you know how to switch between them?
