I’m loving OSMC so far, it’s great but whenever I try to play anything out of the 3.5mm audio jack, I just get a loud distorted noise over the actual audio. When nothing is playing it is very loud, when something is playing it is a little quieter. If I lower the volume on the system and increase the volume on the speakers it gets worse. I am running the latest build of OSMC and the raspberry pi is brand new.
It is not an issue with cables/power/speakers or the settings as I have tried many different ones of each and it does not happen with other distros, such as raspbian. The audio through HDMI is fine, but at my desk I connect it to a monitor that does not have speakers so I need the 3.5mm jack.
I found a similar post from before but there was no solution:
The person just bought a USB sound card and used that to play audio to speakers.
Does anyone know why this happens or how I can fix it?
