first of all, I want to thank you for this great kodi distro! Everything’s working great since the RC1, except for analogue sound output, on my RPI2.
The sound is really bad and I always hear distorted noise, making it impossible to watch anything. I already tried to reinstall, replace the audio cable and the usb cable, nothing seems to make any difference.
Perhaps someone can help me out here, as I really would love to enjoy OSMC to full extent.
The other end is connected to my speakers. The problem is that I run my RPI2 on a 24’’ screen that has no integrated speakers, so I have to use the pi’s analogue output…
Edit: I’m gonna install OSMC to my RPI1 to see if the issue is related to the RPI2
Edit2: However, I remember not having this problem with the Alpha4 on my RPI2.
Edit 3: OK, just tried it on my RPI1, the sound is very low, but there is less distortion. What does that say?
I also got the same issue here: the sound is great through HDMI but sound is not good from analog ouput on a RPI2 (and I need the last one…). Both movies and Kodi interface sounds have distortion issues and very low volume.
I have no problem with a RPI1 and Raspbmc.
I made some further tests and it seems to me that the sound is not correctly balanced: the right channel has a much higher volume that the left one and the left one is almost inaudible but has some sound though.
Could it be related to the fact that RPI2 analog ouput is also a video output? Do we need a special wire or something to have a correct sound?
A headphone type cable has tip–ring–shield, and works with a Pi Model B. The connector in the Pi2 is tip–ring–ring–shield to break out audio and video.
