Downgraded to July update. It still has the output_rgb setting and everthing is fine again. Will wait with updating until a solution is found(or i buy new tv :P). I am sure the pro developers will find some sort of a solution. In all honesty Philips should update it’s firmware tho, because i understand the problem lays there. Thanks Sam and Mensch for feedback.
Would you be happy to test a solution? It may not necessarily work and
require a downgrade again which would be a pain; but I would like to get
this resolved.
I think the Phillips TVs that are affected are quite old, so I think the firmware
updates are unlikely.
I would be willing to test, even if it means downgrading again. The process of getting the box up and running again is a bit of hassle, but if it means the problem will be fixed I’m not that concerned.
The last firmware update for my Philips model is from 2010, so I think it’s highly unlikely that there’s new software in the works at Philips.
It seems I have similar issue with my Vero 4k connected to Sony TV (KDL 40w4000).
Everything is fine when it is connected directly.
But when connected via Yamaha receiver (RX-V463) the black levels 0-16 are reproduced as completely black.
Add the following line: deb http://apt.osmc.tv jessie-devel main
I’ve just updated my installation with the release from the development channel as detailed above. grep VERSION_ID /etc/os-release returns: VERSION_ID="2017.09-1".
Unfortunately the issue still persists. After about a minute in the main menu of OSMC the screen switches to the saturated greens.
