Trying to install the Raspberry Pi Zero 2017.04-1 version to a 32GB Sandisk MicroSDHC card.
I’m using the built-in SDXC card reader on my MacBook Pro and the MicroSD->SD converter which came with my Pi.
I’ve tried several different branded MicroSD cards and a brand new full size 64GB SanDisk SDXC card (ie. without the converter)
OS version is macOS Sierra 10.12.5 on a ‘Mid 2012 13" MacBook Pro’
In all cases, the install fails at the end:
Mon Jun 5 18:02:46 2017 OSMC Installer running on Mac OS X
Mon Jun 5 18:02:47 2017 Detected locale as en_GB
Mon Jun 5 18:02:47 2017 Attempting to load translation for locale en_GB
Mon Jun 5 18:02:47 2017 Could not load translation!
Mon Jun 5 18:02:47 2017 Resolving a mirror
Mon Jun 5 18:02:48 2017 Resolved mirror to http://anorien.csc.warwick.ac.uk/mirrors/osmc/osmc/download/
Mon Jun 5 18:02:48 2017 Enumerating supported devices
Mon Jun 5 18:02:48 2017 Added the following devices
Mon Jun 5 18:02:48 2017 Vero 4K
Mon Jun 5 18:02:48 2017 Vero 2
Mon Jun 5 18:02:48 2017 Raspberry Pi 1 / Zero
Mon Jun 5 18:02:48 2017 Raspberry Pi 2 / 3
Mon Jun 5 18:02:48 2017 Apple TV
Mon Jun 5 18:02:48 2017 Checking for updates
Mon Jun 5 18:02:48 2017 Checking for updates by downloading http://anorien.csc.warwick.ac.uk/mirrors/osmc/osmc/download//installers/latest_mac
Mon Jun 5 18:02:48 2017 Acquired mirror file
Mon Jun 5 18:02:48 2017 No new update is available
Mon Jun 5 18:02:58 2017 The user has selected English as their language
Mon Jun 5 18:02:58 2017 The user has selected Raspberry Pi 1 / Zero as their device
Mon Jun 5 18:02:58 2017 Attempting to download device versions file http://anorien.csc.warwick.ac.uk/mirrors/osmc/osmc/download/installers/versions_RBP
Mon Jun 5 18:02:59 2017 Found a build called 2017.04-1
Mon Jun 5 18:02:59 2017 Found a build called 2017.03-1
Mon Jun 5 18:02:59 2017 Found a build called 2017.02-2
Mon Jun 5 18:02:59 2017 Found a build called 2017.01-1
Mon Jun 5 18:02:59 2017 Found a build called 2016.12-1
Mon Jun 5 18:02:59 2017 Found a build called 2016.11-1
Mon Jun 5 18:02:59 2017 Found a build called 2016.10-1
Mon Jun 5 18:02:59 2017 Found a build called 2016.09-1
Mon Jun 5 18:02:59 2017 Found a build called 2016.08-1
Mon Jun 5 18:03:31 2017 The user has selected an online image for Raspberry Pi 1 / Zero with build URL : http://anorien.csc.warwick.ac.uk/mirrors/osmc/osmc/download/installers/diskimages/OSMC_TGT_rbp1_20170504.img.gz
Mon Jun 5 18:03:31 2017 Disabling internal install for device Raspberry Pi 1 / Zero as it does not support it
Mon Jun 5 18:03:32 2017 SD installation selected
Mon Jun 5 18:03:42 2017 Wireless network configured with SSID xxxxx key value xxxxx
Mon Jun 5 18:03:42 2017 Enumerating imageable devices for OSX
Mon Jun 5 18:03:42 2017 New disk device entry created with entry point /dev/rdisk0, 250.1 GB free space and label
Mon Jun 5 18:03:42 2017 =================================================
Mon Jun 5 18:03:42 2017 Starting to parse /dev/rdisk0 for additional info
Mon Jun 5 18:03:42 2017 MediaName-Line: Device / Media Name: Crucial_CT250MX200SSD1
Mon Jun 5 18:03:42 2017 Protocol-Line: Protocol: SATA
Mon Jun 5 18:03:42 2017 Determined SATA as protocol for /dev/rdisk0
Mon Jun 5 18:03:42 2017 Decided to be a DMG: no
Mon Jun 5 18:03:42 2017 R/O-Line: Read-Only Media: No
Mon Jun 5 18:03:42 2017 parsed/split/simplified readOnly line would have been: No
Mon Jun 5 18:03:42 2017 Determined No as readOnlyMedia for /dev/rdisk0
Mon Jun 5 18:03:42 2017 Decided to be r/o: no
Mon Jun 5 18:03:42 2017 Ejectable-Line: Removable Media: Fixed
Mon Jun 5 18:03:42 2017 Determined Fixed as ejactableProperty for /dev/rdisk0
Mon Jun 5 18:03:42 2017 Decided that /dev/rdisk0 is not writable to us
Mon Jun 5 18:03:42 2017 Parsed device as NON-writable. NOT Appending.
Mon Jun 5 18:03:42 2017 Finished parsing additional info for /dev/rdisk0
Mon Jun 5 18:03:42 2017 New disk device entry created with entry point /dev/rd248.8, Crucial SSD free space and label
Mon Jun 5 18:03:42 2017 Starting to parse /dev/rd248.8 for additional info
Mon Jun 5 18:03:43 2017 Decided that /dev/rd248.8 is not writable to us
Mon Jun 5 18:03:43 2017 Parsed device as NON-writable. NOT Appending.
Mon Jun 5 18:03:43 2017 Finished parsing additional info for /dev/rd248.8
Mon Jun 5 18:03:43 2017 =================================================
Mon Jun 5 18:03:43 2017 New disk device entry created with entry point /dev/rdisk3, +25.4 MB free space and label
Mon Jun 5 18:03:43 2017 Starting to parse /dev/rdisk3 for additional info
Mon Jun 5 18:03:43 2017 MediaName-Line: Device / Media Name: Disk Image
Mon Jun 5 18:03:43 2017 Protocol-Line: Protocol: Disk Image
Mon Jun 5 18:03:43 2017 Determined Disk Image as protocol for /dev/rdisk3
Mon Jun 5 18:03:43 2017 Decided to be a DMG: yes
Mon Jun 5 18:03:43 2017 R/O-Line: Read-Only Media: Yes
Mon Jun 5 18:03:43 2017 parsed/split/simplified readOnly line would have been: Yes
Mon Jun 5 18:03:43 2017 Determined Yes as readOnlyMedia for /dev/rdisk3
Mon Jun 5 18:03:43 2017 Decided to be r/o: yes
Mon Jun 5 18:03:43 2017 Ejectable-Line: Removable Media: Removable
Mon Jun 5 18:03:43 2017 Determined Removable as ejactableProperty for /dev/rdisk3
Mon Jun 5 18:03:43 2017 Decided that /dev/rdisk3 is not writable to us
Mon Jun 5 18:03:43 2017 Finished parsing additional info for /dev/rdisk3
Mon Jun 5 18:03:43 2017 New disk device entry created with entry point /dev/rdisk4, 31.9 GB free space and label
Mon Jun 5 18:03:43 2017 Starting to parse /dev/rdisk4 for additional info
Mon Jun 5 18:03:43 2017 MediaName-Line: Device / Media Name: Built In SDXC Reader
Mon Jun 5 18:03:43 2017 Protocol-Line: Protocol: Secure Digital
Mon Jun 5 18:03:43 2017 Determined Secure Digital as protocol for /dev/rdisk4
Mon Jun 5 18:03:43 2017 Decided to be a DMG: no
Mon Jun 5 18:03:43 2017 R/O-Line: Read-Only Media: No
Mon Jun 5 18:03:43 2017 parsed/split/simplified readOnly line would have been: No
Mon Jun 5 18:03:43 2017 Determined No as readOnlyMedia for /dev/rdisk4
Mon Jun 5 18:03:43 2017 Decided to be r/o: no
Mon Jun 5 18:03:43 2017 Determined Removable as ejactableProperty for /dev/rdisk4
Mon Jun 5 18:03:43 2017 isEjectable: yes; isDmg: no; isReadOnly: no
Mon Jun 5 18:03:43 2017 Parsed device as writable. Appending.
Mon Jun 5 18:03:43 2017 Finished parsing additional info for /dev/rdisk4
Mon Jun 5 18:03:45 2017 Device selected: 3 /dev/rdisk4 31.9 GB Built In SDXC Reader
Mon Jun 5 18:03:48 2017 EULA has been accepted
Mon Jun 5 18:03:48 2017 Downloading http://anorien.csc.warwick.ac.uk/mirrors/osmc/osmc/download/installers/diskimages/OSMC_TGT_rbp1_20170504.img.gz
Mon Jun 5 18:03:50 2017 Extracting /Users/roobarb/OSMC_TGT_rbp1_20170504.img.gz
Mon Jun 5 18:03:55 2017 Finished extraction. Going to write image
Mon Jun 5 18:03:55 2017 Requesting confirmation from user
Mon Jun 5 18:04:12 2017 User confirmed
Mon Jun 5 18:04:12 2017 going to start osa
Mon Jun 5 18:04:12 2017 pasting admin script to process do shell script "dd if=/Users/roobarb/OSMC_TGT_rbp1_20170504.img of=/dev/rdisk4 bs=1m conv=sync && sync" with administrator privileges
Mon Jun 5 18:04:12 2017 waiting for finish
Mon Jun 5 18:04:27 2017 osa claims to be done...collect output and verify
Mon Jun 5 18:04:27 2017 Imaging was successful
Mon Jun 5 18:04:27 2017 Image successfully written to device
Mon Jun 5 18:04:27 2017 Deleting the uncompressed image to save space
Mon Jun 5 18:04:27 2017 Creating preseeder
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i target/storage string sd
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i network/interface string wlan
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i network/auto boolean true
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i network/ssid string xxxxx
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i network/wlan_keytype string 1
Mon Jun 5 18:04:27 2017 Adding preseed stringd-i network/wlan_key string xxxxx
Mon Jun 5 18:04:27 2017 Writing preseeder
Mon Jun 5 18:04:27 2017 Mounting the first filesystem on /dev/rdisk4
Mon Jun 5 18:04:27 2017 Trying to umount before we are remounting and writing the preseed.
Mon Jun 5 18:04:28 2017 Mounting /dev/rdisk4s1 to /var/folders/y2/n240prq94134clzffckxsy6m0000gn/T/osmc_mnt
Mon Jun 5 18:04:28 2017 Could not mount /dev/rdisk4s1. Messages are: stdErr: Volume on disk4s1 failed to mount
If the volume is damaged, try the "readOnly" option
stdOut:
Mon Jun 5 18:04:28 2017 Could not mount filesystem!
Physically reinserting the card works and mounts the partition:
/dev/disk4 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: FDisk_partition_scheme *31.9 GB disk4
1: Windows_FAT_32 NO NAME 254.8 MB disk4s1
Any suggestions?
