Since the upgrade to Kodi v19, the kodi.bin processes cannot be terminated anymore. Neither is systemd able to stop them, nor does kill with any signal succeed. Currently I have 21 kodi.bin processes running. Here is an example from the journal:
10:00:02 Stopping media center application...
10:00:23 mediacenter.service: State 'stop-sigterm' timed out. Killing.
10:00:23 mediacenter.service: Killing process 21697 (mediacenter) with signal SIGKILL.
10:00:23 mediacenter.service: Killing process 29676 (kodi.bin) with signal SIGKILL.
10:00:23 mediacenter.service: Killing process 5555 (kodi.bin) with signal SIGKILL.
10:00:23 mediacenter.service: Killing process 21712 (sudo) with signal SIGKILL.
10:00:23 mediacenter.service: Killing process 21713 (kodi.bin) with signal SIGKILL.
10:00:23 mediacenter.service: Main process exited, code=killed, status=9/KILL
10:00:23 ioctl FBIOPUT_VSCREENINFO: Device or resource busy
10:00:23 mediacenter.service: Failed with result 'timeout'.
10:00:23 Stopped media center application.
10:00:37 mediacenter.service: Found left-over process 29676 (kodi.bin) in control group while starting unit. Ignoring.
10:00:37 This usually indicates unclean termination of a previous run, or service implementation deficiencies.
10:00:37 mediacenter.service: Found left-over process 5555 (kodi.bin) in control group while starting unit. Ignoring.
10:00:37 mediacenter.service: Found left-over process 21713 (kodi.bin) in control group while starting unit. Ignoring.
10:00:37 Started media center application.
10:00:37 Starting Kodi...
The newly started Kodi doesn’t start correctly because of the allocated resources.
I am running OSMC on 3 RasPis and have this problem on 2 of them. On the one making most of the problems I also see some exceptions in the kernel log:
[ 61.296721] 8<--- cut here ---
[ 61.301642] Unable to handle kernel NULL pointer dereference at virtual address 00000280
[ 61.306782] pgd = 5308e88a
[ 61.311785] [00000280] *pgd=00000000
[ 61.316913] Internal error: Oops: 5 [#1] PREEMPT SMP ARM
[ 61.321910] Modules linked in: 8021q garp stp llc iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_filter raid1 vc4 md_mod cec drm_kms_helper drm drm_panel_orientation_quirks snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops backlight brcmfmac raspberrypi_hwmon brcmutil sg sha256_generic bcm2835_codec(C) uas bcm2835_isp(C) v4l2_mem2mem cfg80211 videobuf2_dma_contig bcm2835_v4l2(C) bcm2835_mmal_vchiq(C) videobuf2_vmalloc videobuf2_memops i2c_bcm2835 videobuf2_v4l2 videobuf2_common rfkill videodev mc vc_sm_cma(C) uio_pdrv_genirq uio fixed ip_tables x_tables ipv6
[ 61.334417] CPU: 2 PID: 137 Comm: kworker/2:2 Tainted: G C 5.10.32-2-osmc #1
[ 61.338048] Hardware name: BCM2835
[ 61.341746] Workqueue: events output_poll_execute [drm_kms_helper]
[ 61.345469] PC is at vc4_hdmi_encoder_pre_crtc_configure+0x70/0x620 [vc4]
[ 61.349188] LR is at vc4_crtc_atomic_enable+0x74/0x560 [vc4]
[ 61.352859] pc : [<7f508248>] lr : [<7f4f192c>] psr: 600f0013
[ 61.356566] sp : 827bfc28 ip : 827bfc50 fp : 827bfc4c
[ 61.360280] r10: 83dc8800 r9 : 00000000 r8 : 7f5190b0
[ 61.364001] r7 : 83dc9284 r6 : 83dcf040 r5 : 83dc9284 r4 : 00000000
[ 61.367754] r3 : 00000000 r2 : 00000003 r1 : 00000004 r0 : 81ac0810
[ 61.371520] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 61.375359] Control: 10c5383d Table: 0445406a DAC: 00000055
[ 61.379201] Process kworker/2:2 (pid: 137, stack limit = 0x872bcb2c)
[ 61.383059] Stack: (0x827bfc28 to 0x827c0000)
[ 61.386918] fc20: 83dcf040 84ebd3c0 83dcf040 83dc9284 7f5190b0 00000000
[ 61.390839] fc40: 827bfc9c 827bfc50 7f4f192c 7f5081e4 827bfc94 827bfc60 7f50e340 7f50cfc0
[ 61.394770] fc60: 84e8ae00 00000001 00000004 84ebd3c0 00000018 00000003 84ebd3c0 83dcf040
[ 61.398723] fc80: 7f480028 7f5190b0 00000000 83dc8800 827bfccc 827bfca0 7f46ce40 7f4f18c4
[ 61.402694] fca0: 00000004 00000000 84ebd3c0 83dc8800 843ec840 83dc8ce8 00000000 83dc8800
[ 61.406675] fcc0: 827bfcfc 827bfcd0 7f4fa4f4 7f46cc24 00000001 84ebd3c0 83dc8800 00000000
[ 61.410707] fce0: 00000000 83dc8ce8 00000000 83dc8800 827bfd24 827bfd00 7f4fab40 7f4fa348
[ 61.414765] fd00: 00000000 84ebd3c0 83dc8800 827bfd58 81bdae40 81a91370 827bfd44 827bfd28
[ 61.418832] fd20: 7f3ba150 7f4fa9c8 84ebd3c0 83dc89c0 00000001 827bfd58 827bfdac 827bfd48
[ 61.422909] fd40: 7f3d4824 7f3ba108 81205008 00000000 00000001 82514e00 00000001 82206c80
[ 61.427004] fd60: 00000012 0000001f 00000000 00000000 83dc8d98 822ecc68 00000000 fa7d8818
[ 61.431092] fd80: 80261d88 83dc8800 82514e18 00000000 82514e00 00000000 00000000 7f3f3908
[ 61.435181] fda0: 827bfde4 827bfdb0 7f3d493c 7f3d45d0 82d0e668 83dc8980 827bfdec 7f39b024
[ 61.438213] fdc0: 83dc8800 82514e00 00000000 82514eb4 00000000 00000000 827bfdfc 827bfde8
[ 61.441180] fde0: 7f3d4ab0 7f3d48dc 82514e00 7f482020 827bfe24 827bfe00 7f477330 7f3d4a88
[ 61.444178] fe00: 82514e00 00000000 82514eb4 7f3f6080 83dc889c 00000000 827bfe44 827bfe28
[ 61.447201] fe20: 7f477420 7f477274 82514e00 83dc8800 83dc88b0 7f3f6080 827bfe6c 827bfe48
[ 61.450230] fe40: 7f4781b8 7f47737c 82514e00 83dc8800 83dc88b0 7f3f6080 83dc889c 00000000
[ 61.453247] fe60: 827bfe9c 827bfe70 7f3d3d00 7f478178 7f3a1d6c 8074dac4 81205008 81205008
[ 61.456295] fe80: 83dc8a00 00000001 00000001 83dc8800 827bfef4 827bfea0 7f4615f0 7f3d3c88
[ 61.459369] fea0: 7f3f3908 7f3f3914 baa76a00 7f47e6b8 83dc88ec 00000001 80261d88 00000000
[ 61.462460] fec0: 00000000 fa7d8818 baa73740 83dc8a00 81a4dc80 baa73740 00000080 baa76a00
[ 61.465574] fee0: 00000000 00000000 827bff34 827bfef8 8014962c 7f461534 8026255c 80110710
[ 61.468702] ff00: baa73740 baa73740 baa73740 81a4dc80 81a4dc94 baa73740 00000008 baa73758
[ 61.471845] ff20: 81203d00 baa73740 827bff74 827bff38 80149a78 80149400 80b7e7ec 80def11c
[ 61.475010] ff40: 81349be8 81330f82 827bff74 821966c0 82503300 827be000 801499f0 81a4dc80
[ 61.478184] ff60: 00000000 81971e6c 827bffac 827bff78 80151be4 801499fc 821966e4 821966e4
[ 61.481380] ff80: 827bffac 82503300 80151a48 00000000 00000000 00000000 00000000 00000000
[ 61.484602] ffa0: 00000000 827bffb0 801000ec 80151a54 00000000 00000000 00000000 00000000
[ 61.487820] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 61.491032] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 61.494213] Backtrace:
[ 61.497466] [<7f5081d8>] (vc4_hdmi_encoder_pre_crtc_configure [vc4]) from [<7f4f192c>] (vc4_crtc_atomic_enable+0x74/0x560 [vc4])
[ 61.500766] r9:00000000 r8:7f5190b0 r7:83dc9284 r6:83dcf040 r5:84ebd3c0 r4:83dcf040
[ 61.504191] [<7f4f18b8>] (vc4_crtc_atomic_enable [vc4]) from [<7f46ce40>] (drm_atomic_helper_commit_modeset_enables+0x228/0x278 [drm_kms_helper])
[ 61.507610] r10:83dc8800 r9:00000000 r8:7f5190b0 r7:7f480028 r6:83dcf040 r5:84ebd3c0
[ 61.511027] r4:00000003
[ 61.514508] [<7f46cc18>] (drm_atomic_helper_commit_modeset_enables [drm_kms_helper]) from [<7f4fa4f4>] (vc4_atomic_complete_commit+0x1b8/0x680 [vc4])
[ 61.518036] r10:83dc8800 r9:00000000 r8:83dc8ce8 r7:843ec840 r6:83dc8800 r5:84ebd3c0
[ 61.521577] r4:00000000 r3:00000004
[ 61.525184] [<7f4fa33c>] (vc4_atomic_complete_commit [vc4]) from [<7f4fab40>] (vc4_atomic_commit+0x184/0x1d4 [vc4])
[ 61.528813] r10:83dc8800 r9:00000000 r8:83dc8ce8 r7:00000000 r6:00000000 r5:83dc8800
[ 61.532467] r4:84ebd3c0 r3:00000001
[ 61.536281] [<7f4fa9bc>] (vc4_atomic_commit [vc4]) from [<7f3ba150>] (drm_atomic_commit+0x54/0x60 [drm])
[ 61.539981] r9:81a91370 r8:81bdae40 r7:827bfd58 r6:83dc8800 r5:84ebd3c0 r4:00000000
[ 61.543914] [<7f3ba0fc>] (drm_atomic_commit [drm]) from [<7f3d4824>] (drm_client_modeset_commit_atomic+0x260/0x290 [drm])
[ 61.547662] r7:827bfd58 r6:00000001 r5:83dc89c0 r4:84ebd3c0
[ 61.551612] [<7f3d45c4>] (drm_client_modeset_commit_atomic [drm]) from [<7f3d493c>] (drm_client_modeset_commit_locked+0x6c/0x1ac [drm])
[ 61.555447] r10:7f3f3908 r9:00000000 r8:00000000 r7:82514e00 r6:00000000 r5:82514e18
[ 61.559289] r4:83dc8800
[ 61.563229] [<7f3d48d0>] (drm_client_modeset_commit_locked [drm]) from [<7f3d4ab0>] (drm_client_modeset_commit+0x34/0x50 [drm])
[ 61.566947] r9:00000000 r8:00000000 r7:82514eb4 r6:00000000 r5:82514e00 r4:83dc8800
[ 61.570737] [<7f3d4a7c>] (drm_client_modeset_commit [drm]) from [<7f477330>] (drm_fb_helper_set_par+0xc8/0x108 [drm_kms_helper])
[ 61.574342] r5:7f482020 r4:82514e00
[ 61.578023] [<7f477268>] (drm_fb_helper_set_par [drm_kms_helper]) from [<7f477420>] (drm_fb_helper_hotplug_event.part.5+0xb0/0xc8 [drm_kms_helper])
[ 61.581722] r9:00000000 r8:83dc889c r7:7f3f6080 r6:82514eb4 r5:00000000 r4:82514e00
[ 61.585526] [<7f477370>] (drm_fb_helper_hotplug_event.part.5 [drm_kms_helper]) from [<7f4781b8>] (drm_fbdev_client_hotplug+0x4c/0x27c [drm_kms_helper])
[ 61.589320] r7:7f3f6080 r6:83dc88b0 r5:83dc8800 r4:82514e00
[ 61.593270] [<7f47816c>] (drm_fbdev_client_hotplug [drm_kms_helper]) from [<7f3d3d00>] (drm_client_dev_hotplug+0x84/0xbc [drm])
[ 61.597136] r9:00000000 r8:83dc889c r7:7f3f6080 r6:83dc88b0 r5:83dc8800 r4:82514e00
[ 61.601183] [<7f3d3c7c>] (drm_client_dev_hotplug [drm]) from [<7f4615f0>] (output_poll_execute+0xc8/0x1e0 [drm_kms_helper])
[ 61.605132] r8:83dc8800 r7:00000001 r6:00000001 r5:83dc8a00 r4:81205008
[ 61.609144] [<7f461528>] (output_poll_execute [drm_kms_helper]) from [<8014962c>] (process_one_work+0x238/0x5fc)
[ 61.613147] r10:00000000 r9:00000000 r8:baa76a00 r7:00000080 r6:baa73740 r5:81a4dc80
[ 61.617146] r4:83dc8a00
[ 61.621117] [<801493f4>] (process_one_work) from [<80149a78>] (worker_thread+0x88/0x644)
[ 61.625144] r10:baa73740 r9:81203d00 r8:baa73758 r7:00000008 r6:baa73740 r5:81a4dc94
[ 61.629162] r4:81a4dc80
[ 61.633145] [<801499f0>] (worker_thread) from [<80151be4>] (kthread+0x19c/0x1b4)
[ 61.637164] r10:81971e6c r9:00000000 r8:81a4dc80 r7:801499f0 r6:827be000 r5:82503300
[ 61.641193] r4:821966c0
[ 61.645191] [<80151a48>] (kthread) from [<801000ec>] (ret_from_fork+0x14/0x28)
[ 61.649216] Exception stack(0x827bffb0 to 0x827bfff8)
[ 61.653228] ffa0: 00000000 00000000 00000000 00000000
[ 61.657278] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 61.661308] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 61.665309] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:80151a48
[ 61.669310] r4:82503300
[ 61.673282] Code: e5953034 e3a01004 e5150008 e2800010 (e5937280)
[ 61.677515] ---[ end trace 7c88dffe14713513 ]---
[157.485063] vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
[additional 14 times]
[163.667493] vc4_hdmi 3f902000.hdmi: ASoC: error at snd_soc_dai_startup on 3f902000.hdmi: -19
Last but not least, the RasPi does not start without a monitor/TV connected, even if I set hdmi_force_hotplug=1. In the journal from this boot I find another nullptr exception:
:34:30 krnl: 8<--- cut here ---
:34:30 krnl: Unable to handle kernel NULL pointer dereference at virtual address 00000280
:34:30 krnl: pgd = 3b6661ab
:34:30 krnl: [00000280] *pgd=00000000
:34:30 krnl: Internal error: Oops: 5 [#1] PREEMPT SMP ARM
:34:30 krnl: Modules linked in: vc4(+) cec drm_kms_helper drm drm_panel_orientation_quirks snd_soc_core snd_compress snd_pcm_dmaengine snd_pcm snd_timer snd syscopyarea sysfillrect sysimgblt fb_sys_fops backlight raspberrypi_hw
:34:30 krnl: CPU: 2 PID: 196 Comm: systemd-udevd Tainted: G C 5.10.32-2-osmc #1
:34:30 krnl: Hardware name: BCM2835
:34:30 krnl: PC is at vc4_hdmi_encoder_pre_crtc_configure+0x70/0x620 [vc4]
:34:30 krnl: LR is at vc4_crtc_atomic_enable+0x74/0x560 [vc4]
:34:30 krnl: pc : [<7f54b248>] lr : [<7f53492c>] psr: 600f0013
:34:30 krnl: sp : 835ef728 ip : 835ef750 fp : 835ef74c
:34:30 krnl: r10: 81ace800 r9 : 00000000 r8 : 7f55c0b0
:34:30 krnl: r7 : 81acf284 r6 : 844c3040 r5 : 81acf284 r4 : 00000000
:34:30 krnl: r3 : 00000000 r2 : 00000003 r1 : 00000004 r0 : 81ac4810
:34:30 krnl: Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
:34:30 krnl: Control: 10c5383d Table: 035c406a DAC: 00000055
:34:30 krnl: Process systemd-udevd (pid: 196, stack limit = 0x0fb90f5e)
:34:30 krnl: Stack: (0x835ef728 to 0x835f0000)
:34:30 krnl: f720: 844c3040 83c239c0 844c3040 81acf284 7f55c0b0 00000000
:34:30 krnl: f740: 835ef79c 835ef750 7f53492c 7f54b1e4 835ef794 835ef760 7f551198 7f55486c
:34:30 krnl: f760: 8356cc00 00000001 00000004 83c239c0 00000018 00000003 83c239c0 844c3040
:34:30 krnl: f780: 7f517028 7f55c0b0 00000000 81ace800 835ef7cc 835ef7a0 7f503e40 7f5348c4
:34:30 krnl: f7a0: 00000004 00000000 83c239c0 81ace800 83569840 81acece8 00000000 81ace800
:34:30 krnl: f7c0: 835ef7fc 835ef7d0 7f53d4f4 7f503c24 00000001 83c239c0 81ace800 00000000
:34:30 krnl: f7e0: 00000000 81acece8 00000000 81ace800 835ef824 835ef800 7f53db40 7f53d348
:34:30 krnl: f800: 00000000 83c239c0 81ace800 835ef858 83580840 8230ebb0 835ef844 835ef828
:34:30 krnl: f820: 7f451150 7f53d9c8 83c239c0 81ace9c0 00000001 835ef858 835ef8ac 835ef848
:34:30 krnl: f840: 7f46b824 7f451108 81205008 00000000 00000001 833c2200 00000001 834ccd80
:34:30 krnl: f860: 00000004 0000001f 00000000 00000000 81aced98 83581468 00000000 fa7d8818
:34:30 krnl: f880: 1ed0d49a 81ace800 833c2218 00000000 833c2200 00000000 0000001e 00000000
:34:30 krnl: f8a0: 835ef8e4 835ef8b0 7f46b93c 7f46b5d0 83e53080 00000000 818c0400 7f432024
:34:30 krnl: f8c0: 81ace800 833c2200 00000000 833c22b4 00000000 0000001e 835ef8fc 835ef8e8
:34:30 krnl: f8e0: 7f46bab0 7f46b8dc 833c2200 7f519020 835ef924 835ef900 7f50e330 7f46ba88
:34:30 krnl: f900: 842b8000 83436800 818c0400 813eac00 0000005a 0000001e 835ef974 835ef928
:34:30 krnl: f920: 80798000 7f50e274 835ef944 835ef938 80b7e498 813ecdf0 0000001e 00000000
:34:30 krnl: f940: 00000000 0000005a 813ed40c 818c0400 00000000 818c053c 00000000 00000000
:34:30 krnl: f960: 812050d4 00000000 835ef994 835ef978 807f1cd4 80797ce8 818c0400 80c40918
:34:30 krnl: f980: 00000001 00000000 835ef9fc 835ef998 807f50d4 807f1c14 835efa08 80e3ed70
:34:30 krnl: f9a0: 813ecdf0 80e3ed0c 8134ce2c 835ef9b8 80820a28 8081f03c 813ed310 00000000
:34:30 krnl: f9c0: 0000003e 00000000 80e39d6c 00000001 00000001 813ecdf0 80c40918 00000000
:34:30 krnl: f9e0: 00000000 0000003e 00000001 813ece0c 835efa3c 835efa00 807f5d0c 807f4e1c
:34:30 krnl: fa00: 812ea670 80e3ed70 00000001 835efa18 80b7e7ec 00000000 813eaad8 00000000
:34:30 krnl: fa20: 812e7118 81205008 842b8010 842b8228 835efa5c 835efa40 8079a894 807f5ad0
:34:30 krnl: fa40: 842b8000 00000000 813eaad0 81205c64 835efad4 835efa60 8078a4a8 8079a640
:34:30 krnl: fa60: 80e39860 00000000 835efa9c 00000000 00000000 000002d0 000001e0 00000000
:34:31 krnl: fa80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
:34:31 krnl: faa0: 00000020 fa7d8818 00000000 833c2200 81205008 00000000 833c22b4 7f519020
:34:31 krnl: fac0: 00000000 842b8000 835efb44 835efad8 7f50de54 8078a2b8 7f53591c 81ace800
:34:31 krnl: fae0: 00000010 833c2218 83c23600 81ace800 00000000 00000000 000002d0 000001e0
:34:31 krnl: fb00: 000002d0 000001e0 00000010 00000010 833c2400 fa7d8818 835efb44 833c2200
:34:31 krnl: fb20: 81ace800 00000010 7f519020 833c22b4 00000001 812ee648 835efb6c 835efb48
:34:31 krnl: fb40: 7f50f2c4 7f50da98 81ace800 00000010 833c2200 00000000 81ace9cc 00000001
:34:31 krnl: fb60: 835efb94 835efb70 7f50f49c 7f50f178 81ace800 81ac4c10 81ace800 81ac4c10
:34:31 krnl: fb80: 00000000 81ace9c4 835efbbc 835efb98 7f535be0 7f50f3f4 83efc240 82d01ca8
:34:31 krnl: fba0: 81adf2c0 82d01ca8 83efc3c0 00000008 835efbf4 835efbc0 8081c848 7f535948
:34:31 krnl: fbc0: 8081cc58 00000000 8081cad0 83efc3c0 812ee648 81ac4c10 7f55c954 7f5697cc
:34:31 krnl: fbe0: 81ac4c10 00000000 835efc1c 835efbf8 8081ccd0 8081c6e8 80c48568 7f53571c
:34:31 krnl: fc00: 81205008 7f55ced8 81ac4a10 7f53571c 835efc5c 835efc20 7f535ca8 8081cc04
:34:31 krnl: fc20: 81ac4a10 00000000 81adf2c0 fa7d8818 8083d7a8 81ac4c10 00000000 7f569150
:34:31 krnl: fc40: 00000000 7f569150 00000029 00000000 835efc7c 835efc60 808283bc 7f535c08
:34:31 krnl: fc60: 81ac4c10 813ee0c0 813ee0c8 00000000 835efcb4 835efc80 80825b3c 80828370
:34:31 krnl: fc80: 80b7e76c 8015c228 835efcb4 81ac4c10 7f569150 81ac4c54 80826410 00000000
:34:31 krnl: fca0: 7f56998c 835eff30 835efccc 835efcb8 808261d4 80825a44 81ac4c10 7f569150
:34:31 krnl: fcc0: 835efcec 835efcd0 80826580 80826174 819b61b4 81205008 7f569150 80826410
:34:31 krnl: fce0: 835efd1c 835efcf0 80823580 8082641c 835efd0c 819ff058 819b61b4 fa7d8818
:34:31 krnl: fd00: 7f569150 812eec18 8376de00 00000000 835efd2c 835efd20 808254b8 80823508
:34:31 krnl: fd20: 835efd54 835efd30 80824ed8 80825498 7f562748 80b7e470 7f569150 00000000
:34:31 krnl: fd40: 00000001 00000000 835efd6c 835efd58 80827070 80824d1c 81205008 7f212000
:34:31 krnl: fd60: 835efd7c 835efd70 80828310 80826fe4 835efd8c 835efd80 7f212040 808282cc
:34:31 krnl: fd80: 835efe04 835efd90 80102594 7f21200c 00000001 80358e38 00000001 80358e38
:34:31 krnl: fda0: 7f56998c 82513900 00000059 80381e98 835efe04 835efdc0 80381e98 80333010
:34:31 krnl: fdc0: 835efe14 835efdd0 80358e38 00000008 801e913c 82514b80 82514a40 fa7d8818
:34:31 krnl: fde0: 7f569ab0 7f569980 82514b40 00000001 00000000 00000000 835efe2c 835efe08
:34:31 krnl: fe00: 801e9178 80102550 835efe2c 835efe18 7f569980 7f569ab0 00000001 00000000
:34:31 krnl: fe20: 835eff14 835efe30 801ec408 801e9114 ffff8000 00007fff 7f569980 801e6ab8
:34:31 krnl: fe40: 803a0d2c 80df7e48 80df7e60 80df7df0 7f220a5b 7f569b8c 7f56998c 80c038e4
:34:31 krnl: fe60: 00000003 76ddb59c 80df7eb0 81205008 81203e00 7f569980 80df799c 835e0001
:34:31 krnl: fe80: 00000000 80ea2630 80e8c628 00000000 00000000 00000000 00000000 00000000
:34:31 krnl: fea0: 00000000 00000000 6e72656b 00006c65 00000000 00000000 00000000 00000000
:34:31 krnl: fec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
:34:31 krnl: fee0: 00000000 fa7d8818 835eff2c 81205008 00000000 76ddb59c 0000001d 80100204
:34:31 krnl: ff00: 835ee000 0000017b 835effa4 835eff18 801ecbb4 801e9578 835eff2c 7fffffff
:34:31 krnl: ff20: 00000000 00000002 00000000 bbcd1000 bbd04da7 bbd0b680 bbcd1000 000584c8
:34:31 krnl: ff40: bbd28cd0 bbd28af0 bbd13f90 00038000 0003e8d0 0000e410 00042959 00000000
:34:31 krnl: ff60: 00000000 00000000 0000e400 00000030 00000031 00000028 00000017 00000010
:34:31 krnl: ff80: 00000000 fa7d8818 0169d9a0 00000000 e63f8300 0000017b 00000000 835effa8
:34:31 krnl: ffa0: 801001e4 801ecaf8 0169d9a0 00000000 0000001d 76ddb59c 00000000 0169ee00
:34:31 krnl: ffc0: 0169d9a0 00000000 e63f8300 0000017b 016a8170 00511898 00000000 016b1aa0
:34:31 krnl: ffe0: 7ece1150 7ece1140 76dd51cd 76e85d92 40070030 0000001d 00000000 00000000
:34:31 krnl: Backtrace:
:34:31 krnl: [<7f54b1d8>] (vc4_hdmi_encoder_pre_crtc_configure [vc4]) from [<7f53492c>] (vc4_crtc_atomic_enable+0x74/0x560 [vc4])
:34:31 krnl: r9:00000000 r8:7f55c0b0 r7:81acf284 r6:844c3040 r5:83c239c0 r4:844c3040
:34:31 krnl: [<7f5348b8>] (vc4_crtc_atomic_enable [vc4]) from [<7f503e40>] (drm_atomic_helper_commit_modeset_enables+0x228/0x278 [drm_kms_helper])
:34:31 krnl: r10:81ace800 r9:00000000 r8:7f55c0b0 r7:7f517028 r6:844c3040 r5:83c239c0
:34:31 krnl: r4:00000003
:34:31 krnl: [<7f503c18>] (drm_atomic_helper_commit_modeset_enables [drm_kms_helper]) from [<7f53d4f4>] (vc4_atomic_complete_commit+0x1b8/0x680 [vc4])
:34:31 krnl: r10:81ace800 r9:00000000 r8:81acece8 r7:83569840 r6:81ace800 r5:83c239c0
:34:31 krnl: r4:00000000 r3:00000004
:34:31 krnl: [<7f53d33c>] (vc4_atomic_complete_commit [vc4]) from [<7f53db40>] (vc4_atomic_commit+0x184/0x1d4 [vc4])
:34:31 krnl: r10:81ace800 r9:00000000 r8:81acece8 r7:00000000 r6:00000000 r5:81ace800
:34:31 krnl: r4:83c239c0 r3:00000001
:34:31 krnl: [<7f53d9bc>] (vc4_atomic_commit [vc4]) from [<7f451150>] (drm_atomic_commit+0x54/0x60 [drm])
:34:31 krnl: r9:8230ebb0 r8:83580840 r7:835ef858 r6:81ace800 r5:83c239c0 r4:00000000
:34:31 krnl: [<7f4510fc>] (drm_atomic_commit [drm]) from [<7f46b824>] (drm_client_modeset_commit_atomic+0x260/0x290 [drm])
:34:31 krnl: r7:835ef858 r6:00000001 r5:81ace9c0 r4:83c239c0
:34:31 krnl: [<7f46b5c4>] (drm_client_modeset_commit_atomic [drm]) from [<7f46b93c>] (drm_client_modeset_commit_locked+0x6c/0x1ac [drm])
:34:31 krnl: r10:00000000 r9:0000001e r8:00000000 r7:833c2200 r6:00000000 r5:833c2218
:34:31 krnl: r4:81ace800
:34:31 krnl: [<7f46b8d0>] (drm_client_modeset_commit_locked [drm]) from [<7f46bab0>] (drm_client_modeset_commit+0x34/0x50 [drm])
:34:31 krnl: r9:0000001e r8:00000000 r7:833c22b4 r6:00000000 r5:833c2200 r4:81ace800
:34:31 krnl: [<7f46ba7c>] (drm_client_modeset_commit [drm]) from [<7f50e330>] (drm_fb_helper_set_par+0xc8/0x108 [drm_kms_helper])
:34:31 krnl: r5:7f519020 r4:833c2200
:34:31 krnl: [<7f50e268>] (drm_fb_helper_set_par [drm_kms_helper]) from [<80798000>] (fbcon_init+0x324/0x630)
:34:31 krnl: r9:0000001e r8:0000005a r7:813eac00 r6:818c0400 r5:83436800 r4:842b8000
:34:32 krnl: [<80797cdc>] (fbcon_init) from [<807f1cd4>] (visual_init+0xcc/0x114)
:34:32 krnl: r10:00000000 r9:812050d4 r8:00000000 r7:00000000 r6:818c053c r5:00000000
:34:32 krnl: r4:818c0400
:34:32 krnl: [<807f1c08>] (visual_init) from [<807f50d4>] (do_bind_con_driver+0x2c4/0x5e8)
:34:32 krnl: r7:00000000 r6:00000001 r5:80c40918 r4:818c0400
:34:32 krnl: [<807f4e10>] (do_bind_con_driver) from [<807f5d0c>] (do_take_over_console+0x248/0x450)
:34:32 krnl: r10:813ece0c r9:00000001 r8:0000003e r7:00000000 r6:00000000 r5:80c40918
:34:32 krnl: r4:813ecdf0
:34:32 krnl: [<807f5ac4>] (do_take_over_console) from [<8079a894>] (fbcon_fb_registered+0x260/0x3e8)
:34:32 krnl: r10:842b8228 r9:842b8010 r8:81205008 r7:812e7118 r6:00000000 r5:813eaad8
:34:32 krnl: r4:00000000
:34:32 krnl: [<8079a634>] (fbcon_fb_registered) from [<8078a4a8>] (register_framebuffer+0x1fc/0x2d4)
:34:32 krnl: r7:81205c64 r6:813eaad0 r5:00000000 r4:842b8000
:34:32 krnl: [<8078a2ac>] (register_framebuffer) from [<7f50de54>] (__drm_fb_helper_initial_config_and_unlock+0x3c8/0x590 [drm_kms_helper])
:34:32 krnl: r10:842b8000 r9:00000000 r8:7f519020 r7:833c22b4 r6:00000000 r5:81205008
:34:32 krnl: r4:833c2200
:34:32 krnl: [<7f50da8c>] (__drm_fb_helper_initial_config_and_unlock [drm_kms_helper]) from [<7f50f2c4>] (drm_fbdev_client_hotplug+0x158/0x27c [drm_kms_helper])
:34:32 krnl: r10:812ee648 r9:00000001 r8:833c22b4 r7:7f519020 r6:00000010 r5:81ace800
:34:32 krnl: [<7f50f16c>] (drm_fbdev_client_hotplug [drm_kms_helper]) from [<7f50f49c>] (drm_fbdev_generic_setup+0xb4/0x19c [drm_kms_helper])
:34:32 krnl: r9:00000001 r8:81ace9cc r7:00000000 r6:833c2200 r5:00000010 r4:81ace800
:34:32 krnl: [<7f50f3e8>] (drm_fbdev_generic_setup [drm_kms_helper]) from [<7f535be0>] (vc4_drm_bind+0x2a4/0x2c0 [vc4])
:34:32 krnl: r7:81ace9c4 r6:00000000 r5:81ac4c10 r4:81ace800
:34:32 krnl: [<7f53593c>] (vc4_drm_bind [vc4]) from [<8081c848>] (try_to_bring_up_master+0x16c/0x1b8)
:34:32 krnl: r9:00000008 r8:83efc3c0 r7:82d01ca8 r6:81adf2c0 r5:82d01ca8 r4:83efc240
:34:32 krnl: [<8081c6dc>] (try_to_bring_up_master) from [<8081ccd0>] (component_master_add_with_match+0xd8/0x1a4)
:34:32 krnl: r10:00000000 r9:81ac4c10 r8:7f5697cc r7:7f55c954 r6:81ac4c10 r5:812ee648
:34:32 krnl: r4:83efc3c0
:34:32 krnl: [<8081cbf8>] (component_master_add_with_match) from [<7f535ca8>] (vc4_platform_drm_probe+0xac/0xd0 [vc4])
:34:32 krnl: r7:7f53571c r6:81ac4a10 r5:7f55ced8 r4:81205008
:34:32 krnl: [<7f535bfc>] (vc4_platform_drm_probe [vc4]) from [<808283bc>] (platform_drv_probe+0x58/0xa8)
:34:32 krnl: r10:00000000 r9:00000029 r8:7f569150 r7:00000000 r6:7f569150 r5:00000000
:34:32 krnl: r4:81ac4c10
:34:32 krnl: [<80828364>] (platform_drv_probe) from [<80825b3c>] (really_probe+0x104/0x4d8)
:34:32 krnl: r7:00000000 r6:813ee0c8 r5:813ee0c0 r4:81ac4c10
:34:32 krnl: [<80825a38>] (really_probe) from [<808261d4>] (driver_probe_device+0x6c/0xc4)
:34:32 krnl: r10:835eff30 r9:7f56998c r8:00000000 r7:80826410 r6:81ac4c54 r5:7f569150
:34:32 krnl: [<80826168>] (driver_probe_device) from [<80826580>] (__driver_attach+0x170/0x1d0)
:34:32 krnl: r5:7f569150 r4:81ac4c10
:34:32 krnl: [<80826410>] (__driver_attach) from [<80823580>] (bus_for_each_dev+0x84/0xc4)
:34:32 krnl: r7:80826410 r6:7f569150 r5:81205008 r4:819b61b4
:34:32 krnl: [<808234fc>] (bus_for_each_dev) from [<808254b8>] (driver_attach+0x2c/0x30)
:34:32 krnl: r7:00000000 r6:8376de00 r5:812eec18 r4:7f569150
:34:32 krnl: [<8082548c>] (driver_attach) from [<80824ed8>] (bus_add_driver+0x1c8/0x1e8)
:34:32 krnl: [<80824d10>] (bus_add_driver) from [<80827070>] (driver_register+0x98/0x128)
:34:32 krnl: r7:00000000 r6:00000001 r5:00000000 r4:7f569150
:34:32 krnl: [<80826fd8>] (driver_register) from [<80828310>] (__platform_driver_register+0x50/0x58)
:34:32 krnl: r5:7f212000 r4:81205008
:34:32 krnl: [<808282c0>] (__platform_driver_register) from [<7f212040>] (vc4_drm_register+0x40/0x1000 [vc4])
:34:32 krnl: [<7f212000>] (vc4_drm_register [vc4]) from [<80102594>] (do_one_initcall+0x50/0x2ec)
:34:32 krnl: [<80102544>] (do_one_initcall) from [<801e9178>] (do_init_module+0x70/0x340)
:34:32 krnl: r8:00000000 r7:00000000 r6:00000001 r5:82514b40 r4:7f569980
:34:32 krnl: [<801e9108>] (do_init_module) from [<801ec408>] (load_module+0x2e9c/0x33c4)
:34:32 krnl: r7:00000000 r6:00000001 r5:7f569ab0 r4:7f569980
:34:32 krnl: [<801e956c>] (load_module) from [<801ecbb4>] (sys_finit_module+0xc8/0xfc)
:34:32 krnl: r10:0000017b r9:835ee000 r8:80100204 r7:0000001d r6:76ddb59c r5:00000000
:34:32 krnl: r4:81205008
:34:32 krnl: [<801ecaec>] (sys_finit_module) from [<801001e4>] (__sys_trace_return+0x0/0x1c)
:34:32 krnl: Exception stack(0x835effa8 to 0x835efff0)
:34:32 krnl: ffa0: 0169d9a0 00000000 0000001d 76ddb59c 00000000 0169ee00
:34:32 krnl: ffc0: 0169d9a0 00000000 e63f8300 0000017b 016a8170 00511898 00000000 016b1aa0
:34:32 krnl: ffe0: 7ece1150 7ece1140 76dd51cd 76e85d92
:34:32 krnl: r7:0000017b r6:e63f8300 r5:00000000 r4:0169d9a0
:34:32 krnl: Code: e5953034 e3a01004 e5150008 e2800010 (e5937280)
:34:32 krnl: ---[ end trace a7f7220ab141a0f8 ]---
:34:32 krnl: md/raid1:md0: active with 2 out of 2 mirrors
:34:32 krnl: bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
:34:32 krnl: bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
:34:32 krnl: bcm2835-codec bcm2835-codec: Device registered as /dev/video10
:34:32 krnl: bcm2835-codec bcm2835-codec: Loaded V4L2 decode
:34:32 krnl: bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
:34:32 krnl: bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
:34:32 krnl: bcm2835-isp bcm2835-isp: Register output node 0 with media controller
:34:32 krnl: bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
:34:32 krnl: bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
:34:32 krnl: bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
:34:32 krnl: bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
:34:32 krnl: bcm2835-codec bcm2835-codec: Device registered as /dev/video11
:34:32 krnl: bcm2835-codec bcm2835-codec: Loaded V4L2 encode
:34:32 krnl: bcm2835-codec bcm2835-codec: Device registered as /dev/video12
:34:32 krnl: bcm2835-codec bcm2835-codec: Loaded V4L2 isp
:34:30 systemd-udevd[186]: Worker [196] terminated by signal 11 (SEGV)
:34:30 systemd-udevd[186]: soc:gpu: Worker [196] failed
:34:30 systemd[1]: Reached target Sound Card.
nothing hapens afterwards
